Conservation of energy in a system
The discussion revolves around the conservation of mechanical energy in systems of particles, particularly in the context of a problem involving a block sliding on a track formed by a missing section of a square. Participants explore the application of conservation laws to both individual particles and the center of mass of a system, questioning the assumptions and definitions involved.
  • Participants discuss the application of conservation of energy principles to a system of particles, questioning why mechanical energy should be conserved when nonconservative forces are present. They also explore whether the energy of the center of mass is the only relevant factor in energy conservation, and how individual parts contribute to the overall energy balance.
The discussion is active, with participants raising critical questions about the nature of conservative and nonconservative forces and their implications for energy conservation. Some participants suggest that the conservation laws should apply universally, while others provide examples that challenge this notion, indicating a productive exploration of the topic without reaching a consensus.
Participants express confusion regarding the role of nonconservative forces in energy conservation and the implications for systems of particles. There is acknowledgment of the complexity introduced by interactions between parts of a system and external forces, which may affect energy conservation outcomes.
sspitz
I'm pretty sure I understand everything my book says about force and mechanical energy for point particles. I'm slightly confused about how this applies to systems of particles.
For particles:
The line integral of force over a path is the change in KE. For conservative fields you can set a zero to create a PE function. Therefore, in conservative fields, mechanical energy is constant.
For systems:
All of the above applies to the center of mass of the system with respect to external forces.
In light of this, a lot of the problem I used to do just blindly by conservation of energy seem confusing.
For example (Kleppner 4.4), imagine a square. Remove every part of the square that is a distance R or less from the top right corner. Allow a small block of slide on the track formed by the missing 1/4 circle. Release the block from the top of the track. How fast is it going at the bottom? All surfaces are frictionless.
In the past, I set the zero of PE at the bottom of the track. Momentum is conserved. Then conserve mechanical energy. The initial PE of the block equals the final KE of the block + final KE of the square. Two equations, two unknowns.
This method equates the mechanical energy of the individual elements of the system at two points in time.
However, I no longer see why this is right.
(1) Why is mechanical energy necessarily conserved for anything in this system at all? For the block: the normal force between the block and square is nonconservative. For the system: The normal force between the floor and the square is external and nonconservative.
(2) If mechanical energy is conserved for a system, shouldn't it be the energy of the center of mass that matters, not the energy of the individual parts? Why do the parts in this system have to conserve?
I'm also having trouble writing down all my thoughts clearly all at once, so there may be more in reply to any answers. Thanks in advance.
Forces don't have to be conservative.
The forces you are talking about arise from conservative fields.
The law has to work regardless of how the parts are connected - how does each bit know if it is part of a whole or not, and how do they know where the center of mass is?
Anyway - if only the com has to obey these laws, then it may be possible to gain energy from nowhere by clever rearrangement of the bits about the com... making a perpetual motion machine. Some of the overbalanced wheels seem to be trying to do just that.
However - each bit will not be closed system by itself, so they will gain and lose energy in interactions with other bits.
I'm not sure I understand your meaning. You mean nonconservative forces exist? Could you explain why the contact forces are conservative?
But there are cases where the com conserves mechanical energy, but the parts added together do not. For example, a completely inelastic collision. My understanding is that this happens because the contact force between the colliding elements is nonconservative.
So it seems to me that given two elements in a conservative field that exert a nonconservative force on each other, the com will conserve energy, but the elements will not.
The contact forces arise in reaction to conservative force-fields.
An example of a non-conservative force would be friction: work against friction depends on the path taken. Here's another one.
Strictly speaking you only get nonconservative effects when you have missed out some of the energy conversions. Sometimes it makes for easier calculations - for instance, when a ball-bearing whacks into window-putty and sticks ... that would be inelastic right? So you'd expect that the com would conserve energy and momentum then? But what if the putty is also stuck to the table? In this case, the com also does not act like it conserves anything.
The energy of the ball goes into deforming the putty and manifests as internal energies (heat etc). The putty wants to move but the momentum gets channelled to the table instead, which is heavy and the floor is rough - maybe it moves a micron?
Similarly with friction, some energy goes into heat and sound for example.
At the QM level you can have changes which, although all the bits conserve energy, you get entropy. But at this level we have stopped talking in terms of forces completely.
