Using Special Case of Elastic Collisions in one dimension
The discussion clarifies that the equation for elastic collisions, which states that the relative velocity reverses, applies to bodies of different masses. While bodies of equal mass can exchange velocities, this is not the case for differing masses. An example illustrates how to calculate relative velocities before and after a collision, emphasizing that the reversal of relative velocity alone does not determine final speeds. To find the final velocities, conservation of momentum must also be applied. The insights gained are appreciated, even if not directly relevant to an upcoming test.
Seydlitz
Is it to possible to use the special case of elastic collisions in one dimension with bodies that posses different mass. Ordinarily I know that if the body has same mass the velocity of the bodies will simply be exchanged but is the fact also hold for body with different masses?
v_1 - v_2 = v_2' - v_1'
The equation you posted--which states that the relative velocity reverses in an elastic collision--applies regardless of the masses. But it does not allow you to conclude that velocities are simply exchanged. (That's even more of a special case.)
Ah okay, so what the above equation actually state? I'm confused with the meaning that the relative velocity is simply reversed.
I'll give an example. Before they collide, say m1 is moving with speed 3 m/s to the east and m2 is moving with speed 4 m/s to the west. Taking east as positive, the relative velocity of m2 with respect to m1 before the collision is: V2 - V1 = -4 - 3 = -7 m/s.
So the relationship expressed in the equation above states that whatever happens during the elastic collision, they must end up such that the relative speed of m2 with respect to m1 after the collision is: V'2 - V'1 = +7 m/s. That's what reversed means. Of course this fact alone is not enough to determine those final speeds. You'll have to combine it with another relationship, such as conservation of momentum.
Ah now I get it, thank you for the help Doc. :D
This problem does not actually appear in my test today but it is really helpful to gain new insight from this.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
