How to Start a New Paragraph under Numbering in MS Word 2003
  • Thread starter Thread starter yungman
To start a new paragraph under a numbered section in Word 2003 without incrementing the number, it is recommended to use section headings for numbering rather than paragraph numbering. This allows for multiple paragraphs within a single numbered section. For specific passages that require numbering, consider using minor headings or margin references. Utilizing Shift+Return can create a new paragraph within a numbered item without changing the number. Additionally, some users suggest deleting the automatic number to maintain formatting.
yungman
I have the 2003 Word. I don't know how to start a new paragraph under numbering without getting a new number.
For example I set up using numbering for each paragraph so I start with 1). Every time I hit return, it will start a new paragraph and with 2) on it. I want to start a new paragraph under 1) without automatically increment to 2) every time a want to start a new paragraph. But at the same time, I want to maintain the numbering in the document.
Is there any way to do this?
Thanks
Alan
Computer science news on Phys.org
In which case you want to number the sections, not the paragraphs.
Number the section headings would work best - and you can have as many paragraphs in a section as you like. If you want to have a particular passage numbered as well - either use a subsection (minor heading) or put a reference in the margin.
Note: you'll find everyone uses LaTeX instead. It's not just for math.
Perhaps Shift+Return?
This starts a new paragraph within a numbered item.
Can't you just hit delete? If I'm imagining what you're saying, doesn't deleting it stop the numbering?
You make my day! Thanks
Merry Christmas
Alan
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
