Harmonic Oscillator Potential Approximation
The discussion centers on approximating the ground state energy of a particle in a potential defined by V(x) = κ(x² - l²)². The stable equilibrium point is identified at x = l, and the potential is expanded around this point to resemble a harmonic oscillator. The expansion results in V approximating to (1/2)(8κl)(x - l)², which aligns with the form of a harmonic oscillator potential. The ground state energy is derived using the formula E₀ = (ħ/2)√(8κl²/m). The key takeaway is that the approximation leads to a clear understanding of the ground state energy in terms of the harmonic oscillator model.
thelonious
A particle is in a region with the potential
V(x) = κ(x2-l2)2
What is the approximate ground state energy approximation for small oscillations about the location of the potential's stable equilibrium?
ground state harmonic oscillator ~ AeC*x2
My plan is to find the value of x for which V(x) is at stable equilibrium, then expand about that point, and the expansion should look something like the harmonic oscillator potential (1/2*mωx2). Once the potential is known, I know H = p2/2m + V, and I can use <0|H|0> to find the ground state energy, where |0> is the GS energy eigenstate for the harmonic oscillator.
I have found that the stable equilibrium of V(x) is at x = l.
Next, I expanded V(x) about this point and found:
V = 4κl2(x2-2lx+l2) + O(x-l)3
But what can I do about the 2lx term? I need it to get lost in order to get the HO potential, right?
V(x) = κ(x2-l2)2
You don't want to do anything. You want the potential in terms of powers of (x-l), which is exactly what you have.
$$V \cong \frac{1}{2}(8\kappa l)(x-l)^2$$
So, in calculating <0|H|0>, I will have to integrate ∫(x-l)2e-mωx2/\hbardx from l-\epsilon to l+\epsilon
Right?
You don't need to calculate that expectation value, and no, that isn't how you'd calculate the expectation value either. The idea is you can use the approximation that you have a simple harmonic oscillator. What's the ground-state energy of a harmonic oscillator?
So E=\hbarω/2, and V=1/2*kx2=1/2*8κl2(x-l)2.
ω=√(8kl2/m), so E0=\hbar/2*√(8kl2/m)
Right.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
