Relativistic angular momentum and cyclic coordinates
maverick_starstrider
I'm getting myself confused here. If my relativistic Lagrangian for a particle in a central potentai is
L = \frac{-m_0 c^2}{\gamma} - V(r)
should
\frac{d L}{d \dot{\theta}}
not give me the angular momentum (which is conserved)? Instead I get
\frac{d L}{d \dot{\theta}} = -4 m v r^2 \dot{\theta}\gamma
Anyone?
L = - {m_0}{c^2}\sqrt {1 - \frac{{{{\dot r}^2} + {r^2}{{\dot \theta }^2}}}{{{c^2}}}} - V\left( r \right)
so
\frac{{\partial L}}{{\partial \dot \theta }} = \gamma {m_0}{r^2}\dot \theta
What's the problem?
Absolutely nothing apparently. I just did it again this morning and got the right answer. Sorry for the time waste.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
