Need confirmation with my way of solution.
  • Thread starter Thread starter Sanosuke Sagara
The discussion focuses on solving a problem related to rotational motion, specifically calculating the time and number of revolutions until an object comes to rest. It is clarified that converting units to radians per second is unnecessary if consistent units like revolutions per minute are used. The calculation shows that the time to stop from an initial angular velocity of 120 rev/min is approximately 1.33 minutes, with the total number of revolutions before stopping being 80. A participant confirms the calculations and corrects the misunderstanding about the final answer. The thread concludes with the original poster expressing gratitude for the clarification.
Sanosuke Sagara
I am facing problem on question regarding rotational motion.I have my solution and my question in the attachment that followed.
Firstly, let me comment that you don't need to do all that extra work converting everything into rad/s. You can simply leave things in rev/min, as long as you're consistent. The 1.3 answer is the time in minutes for it to come to a rest, not the number of revolutions. Assuming constant angular acceleration:
\alpha = \frac{\Delta \omega}{\Delta t} = \frac{120\textrm{rev/min} - 150\textrm{rev/min}}{1/3\textrm{min}} = -90 \frac{\textrm{rev}}{\textrm{min}^2}
where the negative rate makes sense as it's slowing down. Now, to compute the time it takes to come to a stop, assume it's angular position and time is 0 after then end of that first 20 seconds. Then,
\omega = \omega_0 + \alpha t \implies 0 = 120\frac{\textrm{rev}}{\textrm{min}} + -90\frac{\textrm{rev}}{\textrm{min}^2}t \implies t=\frac{120\frac{\textrm{rev}}{\textrm{min}}}{-90\frac{\textrm{rev}}{\textrm{min}^2}} \implies t=1.\overline{3} \textrm{min}
Now, if it takes 1.\overline{3}minutes to stop from an initial angular velocity of 120 rev/min at a constant acceleration of -90 rev/min/min, then how many revoutions will it take to stop?
Confirm with the number of revolutions made
I have my calculation in the attachment that followed.Do comment if I have any calculation error.
Nope,it's wrong.The last 2n3 lines of your document are wrong.Using these special units (revolutions/minute) will defintely enable u to get to the answer right away.That's because the result for \theta is the final answer,as it already put in terms of revolutions.Atually the angle is 80revolutions*2\pi radians/revolution approx 500 radians.
So the final answer to yor question is 80 revolutions.This is the number the problem is waiting from u.
Daniel.
Thanks for your confirmation and mark with my mistake.Now I have understand what the question want.Thanks again.
