Number Theory WOP: Find Smallest Integer of Form a - bk
The discussion revolves around understanding the well-ordering principle (WOP) in number theory, specifically regarding the existence of the smallest positive integer of the form a - bk, where a and b are positive integers and k is an integer. Participants clarify that the WOP guarantees the existence of a least element in the set S, which consists of integers formed by a - bk, but it does not specify which element is the smallest. The confusion arises over whether k or the expression a - b(-1) represents the smallest element, but it is emphasized that the principle only asserts that such an element exists. The thread highlights the importance of grasping the implications of WOP for those new to proofs in number theory. Overall, the discussion underscores the foundational nature of the well-ordering principle in establishing the existence of minimum values in sets of positive integers.
dashhh
I've just begun number theory and am having a lot of trouble with proofs. I think I am slowly grasping it, but would appreciate some clarification or any tips on the following please.
Show that if a and b are positive integers, then there is a smallest positive integer of the form a - bk, k \in Z
The answer given is:
Let a and b be positive integers and let
S = {n:n is a positive integer and n = a - bk for some k \in Z}
Now S is nonempty since a + b = a - b(-1) is in S. By the well ordering principle, S has a least element.
So, are they implying that k is the smallest element? or a - b(-1) as a whole is the smallest element?
I'm unsure as to how they are showing that it is the smallest element though. Given that either of the two options above would be S_{o}, what value would be the comparing s?
welcome to pf!
hi dashhh! welcome to pf! :wink:
dashhh said:
… By the well ordering principle, S has a least element.
no, they're not saying anything about the smallest element
they're only saying that a smallest element exists
that's all the well ordering principle proves :smile:
Neither. They are saying that a- bk, for that particular k, is the smallest element.
It would seem you are contradicting one another?
Or am i confused all over again?
EDIT: My only understanding of WOP is that you need S_{o}<S
This is all we have learned so far, so based on the fact we should be able to understand (at least vaguely) what is going on with what we are supposed to know, I don't see how this should make sense yet. Is it due to being lacking in the area of proofs?
I should also mention I have actually looked at other resources etc, not just lecture notes.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
