Cylohexanol stability of conformations
  • Thread starter Thread starter Chemist20
    Stability
The discussion centers on the equilibrium between conformers of a molecule where the hydroxyl (OH) group can be positioned axially or equatorially. It is noted that in apolar solvents, the equilibrium favors the axial conformer less than in polar solvents. The role of entropy is mentioned as a potential factor influencing this equilibrium, with a suggestion to consider the impact of dipole moments in polar environments.
Chemist20
There is an equilibrium between the conformer in which OH is axial and the conformer in which OH is equatorial.
axial - equatorial
in apolar solvents, the equilibrium is less displaced to the right than in polar solvents.
Any ideas?
I think it has to do with entropy but not sure how...
Chemistry news on Phys.org
Think dipole moment.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
