Formula for the Length of the pipe.
To find the length of a pipe open at both ends, the wavelength (λ) is calculated using the formula λ = v/f, where v is the speed of sound and f is the frequency. For a second overtone at 2000 Hz and a speed of sound at 343 m/s, the wavelength is determined to be approximately 0.17 m. The relationship between the wavelength and the length of the pipe is crucial, as the length of the pipe is typically a fraction of the wavelength. In this case, the user expresses uncertainty about the correctness of their calculation and plans to seek clarification from their teacher. Understanding the relationship between wavelength and pipe length is essential for solving such problems accurately.
ynehs
The second overtune for a pipe, open at both ends is 2000 Hz, the speed of the sound is 343 m/s. What is the length of the pipe?
• λ = v/f
λ = v/f = (340 m/s)/(2000 Hz) = 0.17 m
don't know if this is correct.
Thanks in advanced.
• λ = v/f
Thanks in advanced.
You found the wavelength of the sound. How is that related to the length of the pipe?
i don't know, it was in the problem given by our teacher. anyways, nvrmind my question, ill just asked him the correct answer.
