Does the idea of inflation in the universe contradict relativity?
fellupahill
I was just reading on inflation and the book was saying that since the universe is expanding, the light we see from stars are now ALOT farther away from us now. This seems to my noob mind to be contradictory to relativity.
If you on a train going 500mph at a beam of light the beam of light is only coming at you at the speed of light. Not the sum of the speeds. First question. Why is this the case? Seems impossible. lol
Second question. Does the universe expanding faster than the speed of light throw any wrenches in current theory? Do the two statements correlate with each other at all? The distance that light travels is the distance it was from us + the inflation distance of the universe . & The speed of light is constant for everyone regardless of velocity.
SR is a local phenomenon. Two objects that are local to each other cannot exceed the speed of light with their relative velocity, but SR does not forbid objects increasing in distance bwetween each other as a result of expansion. Locally, the two objects might as well be stationary; it is the space between them that is expanding.
Because your velocity relative to the source of light results in a time dilation.
Usually, the way this thought experiment is set up, you (F for Fell) are in your spaceship traveling a .9c and you turn on your headlights.
You wait ten seconds and measure your beams having traveled ten light seconds ahead of you.
Me, on Earth (D for Dave), sees F turn on his headlights and D waits ten seconds and measures again. D sees the beam of light having traveled ten light seconds, but sees F following closely behind, having traveled 9 light seconds in that time. F is only 1 light second behind his beams.
How?
Because, at .9c, F is time dilated. Time is moving slower for him as compared to D. During the 10 seconds D waited before measuring, F has experienced much less time passing. As far as he's concerned barely a second has passed. He will wait much longer before deciding that 10 seconds has passed, and taking his measurement.
How?
Perfect. Time dilation. Knew generally what it was, but sadly every book I've read on relativity fails to make the connection in a way that stuck. (at least that I could remember. ha)
But still..."the two objects might as well be stationary; it is the space between them that is expanding" isn't the space still expanding faster than the speed of light? That is how the universe is larger than the age? Are they pretty sure they got this inflation thing right? Sounds to a laymen sort of like an escape goat.(but so did dark matter for the longest time. Till I learned more) Does anyone important think the predicted size and age of the universe not matching c points to a fundamental flaw in our understanding?
Not being a grammar Nazi, but you should try firefox. Stock spell check. I'm terrible at spelling, but it makes me look somewhat intelligent. Someone like you who at first glance only makes typing mistakes could really benefit too. Little red reminders.
Again, special relativity has nothing to say about distant objects moving at > c velocities. It does not violate SR. So there's no reason to go looking for a "better" answer.
I see one typo (bwetween). I do use Firefox, btw.
I hope you're not taking issue with the correct spelling of travelling...:wink:
Dave's post is the way to think about it...
From Lineweaver and Davis:
Galaxies CAN recede at greater than the speed of light . Special relativity does not apply to recession velocity. In expanding space, recession velocity keeps increasing
with distance. Beyond a certain distance, known as the Hubble distance, it exceeds the speed of light. This is not a violation of relativity, because recession velocity is caused
not by motion through space but by the expansion of space.
Lots of good stuff here:
http://space.mit.edu/~kcooksey/teaching/AY5/MisconceptionsabouttheBigBang_ScientificAmerican.pdf
Unsure if you mean inflation or expansion...but yes, pretty sure for both...best explanations and experimental confirmations so far...But only
discovered and confirmed recently...this is NOT 100 year old science.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
