Keeping output air pressure constant.
Victor, an automotive technician, is seeking advice on maintaining a constant output air pressure of 1 psi from a variable source pressure of 125 to 175 psi. He has a 0-5 psi air pressure regulator but experiences fluctuations of +/- 2 psi when the source pressure changes. Suggestions include checking the flow rate, considering a two-stage regulator due to the high source pressure, and using a different regulator model, such as the Fisher Controls 912N. Additionally, incorporating a reservoir or air tank may help stabilize the output pressure. The discussion emphasizes the importance of proper equipment and setup to achieve consistent air pressure.
xxrusianxx
Hello everyone, I am new here and just wanted to take this time to say hi. My name is Victor I am an automotive technician from Boston MA,
I'm really glad I came across this Forum it has deffinetly peaked my interest. With that being said... I do have a question.
I am working on a project which requries 1 psi air pressure. My air source is 125 to 175 psi. So far I have obtained a 0-5 psi air pressure regulator (Dwyer MPR2-0) and can succsessfully set it to 1 psi. However, when my source pressure drops or raises it has a significant effect on my output pressure (+/- 2 psi). Question being, how can I keep my output pressure constant at 1 psi with a variable source pressure?
Hmm. That's odd. The output pressure should remain constant as long as the input is greater than the set point. Only thing I can think of is that your flow rate is too high or your regulator is defective. You might also need to use a 2 stage regulator since the source pressure is so much higher than your output.
After doing some research I found a different regulator that does a better job at keeping constant pressure.
If you don't have one already try putting a resevoir (air tank) on the 1 PSI part of your system to act as a damper.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
