Tsunami receeding water question
  • Thread starter Thread starter cbrauner
    Water
The discussion centers on the phenomenon of water receding from the shore prior to a tsunami wave peak and how this differs from regular wave behavior. The receding water, or leading wave, is characterized by a drop in water level, which can also be an elevation in sea level, depending on the wave's characteristics. This behavior is attributed to the physics of wave propagation, where a single tectonic plate upthrust generates a series of waves, similar to the ripples created by a stone dropped in water. The amplitude of tsunami waves increases as they approach shallower depths due to conservation of energy, leading to a phenomenon where the wave's velocity decreases. The discussion highlights that tsunamis can have smaller precursor waves and emphasizes the complexity of these events, including the duration of earthquakes, which typically last 30-60 seconds, contributing to the series of waves generated.
cbrauner
1. What causes water to leave the shore preceeding the tsunami wave peak?
2. Is the cause of that receeding water different from when regular waves approach the shore?
preceding trough
The two responses regarding the "outflow" of water preceding the tsunami wave do not support each other. I need a better explanation of the physics.
Furthermore, how does a single upthrust of a tectonic plate generate a series of waves?
The same way dropping a stone in a lake creates a series of waves - it starts an oscillation that continues until damped. Water is pushed away, then rebounds (actually sending a column of water up), then that water falls away, etc., etc., etc.
http://www.cc.gatech.edu/gvu/animation/Areas/secondary/closeUpDiveSplash.html animation from NOAA, you can see that the biggest trough also preceded the biggest wave (the dark blue line) - obviously its a much more complicated event than a single splash, though. It also looks like what traveled west was a different shape - probably due to the sea-foor shape.
Also, an earthquake isn't a single event: they generally last 30-60 seconds, which also causes a series of waves.
Thank you
Thank you Russ.
We just learned of this website and were figuring out how it works.
This more detailed explanation and links helped to expand and clairfy your first explanation in the other thread. We didn't realize that there were smaller "tsunami" waves that came before the large one or that they could cause such a big trough before the "big" wave first hit land.
The 'leading wave' of a tsunami is depression or drop in water level, however the leading wave can also be an elevation or rise in sea level.
A Tsunami is a wave which damps off as its amplitude increases. The increase in amplitude is due to a decrease in waveform velocity due to a shallowing ocean depth and conservation of wave energy.
Tsunami celerity velocity:
v_c = \sqrt{gd}
g - gravitational acceleration constant.
d - ocean depth
A tsunami 'wave recession' is a 'leading wave' of negative amplitude. The negative amplitude height being equal to the height difference between its maximum recession ocean level and its 'normal' ocean level.
Reference:
http://www.prh.noaa.gov/itic/library/pubs/glossary/tsu_glossary_images/bigimage1_pg14.jpg
http://www.scubageek.com/geek/articles/wwwceler.html
Tsunami Photos:
http://img93.exs.cx/img93/6783/tsunami29bh.jpg
http://img93.exs.cx/img93/4707/tsunami39ge.jpg
http://img93.exs.cx/img93/6052/tsunami45sw.jpg
http://img93.exs.cx/img93/4176/tsunami53jm.jpg
http://img84.exs.cx/img84/7036/tsunami61kb.jpg
http://img84.exs.cx/img84/8669/tsunami72fb.jpg
http://www.pmel.noaa.gov/tsunami/Oceans99/Images/pic_1_2.jpg
http://www.buffalonews.com/graphics/2004/12/27/actualsize/1227waves.jpg
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
These last days, there is a seemingly endless cluster of rather powerful earthquakes close to the islands of Santorini, Amorgos, Anafi, and Ios. Remember, this is a highly volcanically active region, Santorini especially being famous for the supervolcanic eruption which is conjectured to have led to the decline of the Minoan civilization: https://en.m.wikipedia.org/wiki/Minoan_eruption To grasp the scale of what is happening, between the 26th of January and the 9th of February, 12000...
