Charge Density Function to Solve Poisson Eq.
sarperb
This is not really a homework just studying but I'm kinda stuck.
So I am trying to find out how to formally write down the Charge Density for any distribution.
Although I will not get into Green's Function or how to find V, I got that fine.
My example will be a Rod of uniformly distributed charge (total Q) inside a grounded sphere.
-\nabla^{2}V(\vec{r}) = \frac{\rho(\vec{r})}{\epsilon_{0}}
Note: In the below equations w = cosθ for simplicity.
So trying to write down the charge density for a Rod of Charge;
\rho(\vec{r}) = A(r) U(R-r) (δ(w-1)+δ(w+1))
Q = \int^{\infty}_{0}r^{2}A(r)dr\;U(R-r)\;(1+1)\;2\pi
\frac{Q}{4\pi\;} = \int^{R}_{0}r^{2}A(r)dr
So now I can take the integral if I assume A(r) to be a constant in r, or I can say it is proportial to 1/r, or I can say it is proportional to 1/r^{2} all of which will give me an answer which is dimensionally correct.
Although only when I say A(r) is a function of 1/r^{2} I get the right answer for V after I go thru the Green's Function process.
Which is;
V_{in}(r,w) = \frac{Q}{4\pi\epsilon_{0}R}[ln(\frac{r}{R})+\sum^{\infty}_{\ell=2 (Even)}\frac{(2\ell+1)}{\ell(\ell+1)}(1-(\frac{r}{R})^{\ell})P_{\ell}(w)]
Note that this confusion does not arise when one has a dirac delta in r because it doesn't really matter, the delta will kill all r when we are taking the Green's Function integral anyway - so the answer to the question does not change. It only arises when one has a Step Function.
As another example for comparison, a very similar situation arises for an Annulus of Charge with radii a and b.
\rho(\vec{r}) = A(r) U(b-r) U(r-a) δ(w)
Q = \int^{\infty}_{0}r^{2}A(r)dr\;U(b-r) U(r-a)\;2\pi
\frac{Q}{2\pi\;} = \int^{b}_{a}r^{2}A(r)dr
Now in the notes of our instructor this charge density is given as:
\rho(\vec{r}) = \frac{Q}{\pi(b^{2}-a^{2})r}\;U(b-r) U(r-a) δ(w)
So although this looked almost exactly the same while trying to find A(r), here I can see that A(r) is a function of 1/r, but in the case of the rod it was 1/r^{2}.So in the end my question is, how do I know what A(r) should be in terms of r dependance?
Because in the Rod case it is 1/r^{2} and in the Annulus case it is 1/r. I know we can assume A(r) to be a constant, or a function of 1/r, or 1/r^2. But how do I know which one to choose? Thank you for any help!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
