Congruence problem finding smallest modulus.
  • Thread starter Thread starter sg001
    Modulus
sg001
Solve the congruence 20x \equiv16 (mod 92)
Give your answer to the smallest possible modulus.
so 20x -92y=16
Hence,
92=20(4) +12...
gcd = 4
working back,
I have -16(-9)= z (mod 92)
so z = 52
and if I divide through by my gcd =4
36\equiv 13 (mod 23)
but the answer says -36\equiv 10 (mod 23)
Im lost.
Try explaining what you're doing, and do it without so much shorthand.
Ok, I was being lazy
Here it is step by step.
20x\equiv16(mod92)
so..
20x - 92y =16
20 goes into 92, 4 times with 12 remainder
Hence,
92 = 20(4) + 12
12 = 92 - 20(4)
20= 12(1) + 8
8= 20 - 12(1)
12= 8(1) + 4
4= 12 - 8(1)
8= 4(2) + 0 \Rightarrow gcd = 4
working backwards
4= 12 - (20-12)
= (92-20(4)) - (20-12)
= (92-20(4)) - (20-(92-20(4)))
= 92(2) -9(20)
so..
-16(-9) = (?) (mod92)
144 = 52 (mod92)
Now dividing through by gcd...
But the answer says
-36\equiv10(mod23)
I don't understand?
sg001 said:
20x - 92y =16
4 = 92(2) -9(20)
I was more interested in having you explain what you're doing and why you're doing it, than detailing the individual steps in actually doing it.
This far, I can determine you intended to find gcd(92,20), along with coefficients u,v satisfying
gcd(92,20) = 92u + 20v​
I won't ask why you went off into this calculation, since it's frequently useful enough that it's probably fine to do habitually and without comment.However, I can't tell what you were intending to do with the rest of your work:
so..
144 = 52 (mod92)Now dividing through by gcd...
36\equiv 13 (mod 23)But the answer says
-36\equiv10(mod23)
I don't understand?
I figured it out I just was shown a bad way with a simpler problem and have been using that approach since.(I was only using one coefficient instead of the two).
Thanks for the help thoe.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
