Quantum physics problem- Bra-Ket notation and operators
The discussion centers on the confusion surrounding the application of bra-ket notation and rotation operators in quantum mechanics. The user struggles with deriving the state transformation of a photon under a rotation operator, finding discrepancies between their results and those presented in a textbook. They note that while the textbook suggests a direct application of the rotation matrix leads to Psi(theta + phi), their calculations yield Psi(phi - theta) unless they transpose the matrix. The conversation highlights the importance of understanding active versus passive transformations in coordinate systems, which clarifies the sign differences in rotation matrices. Overall, the thread emphasizes the need for a deeper grasp of operator effects on quantum states and the nuances of mathematical representation in quantum mechanics.
max_jammer
Hello all,
I’m trying to derive a result from a book on quantum mechanics but I have trouble with bra-ket notation and operators…
Let’s say we have a photon moving along the cartesian z-axis. It is polarized and its state is
Psi(theta) = cos (theta) x1 + sin(theta) x1
Here, x1 and x2 are the base vectors.
The book states that a rotation about z axis is represented by an operator U, which has the matrix (respective to x1 and x2 base):
cos(fi) sin(fi)
-sin(fi) cos(fi)
It is the next step I have trouble with, the book states that by applying a rotation to psi(theta) you will get psi(theta+fi).
When I use simple matrix multiplication of U and psi, I don’t get this result but rather Psi(fi-theta)…
I did manage to produce the correct result when I used hermetian conjugate od U… Why is this so?
What is the correct procedure and why? What am I doing wrong?
Simple matrix multiplication...
Thanks for your replay.
I did actually do quite extensive search on the web, but I did not find what I was looking for.
Maybe I should explain...
The matrix (for the base \chi_{1} and \chi_{2}) of the rotation operator is (according to the book):
U_{\phi, \textbf{k}} =
cos \phi sin \phi
-sin \phi cos \phi
the state of the photon is
\Psi_{\theta} = cos \theta \chi_{1} + sin \theta \chi_{2}
The book also states that when rotating this state by the rotation matrix above, you will get
\Psi_{\theta + \phi}
But this is not what I get unless I transpose the rotation matrix.
If I do that, the matrix looks exactly like the one in the wikipedia article.
So is the book wrong?
The most confusing part of it all is when I look at the lecture notes. According to those, the professor first calculated the effect of the rotation on the base, like this:
\widehat{U_{\phi, \textbf{k}}} | \chi_{1} > = cos \phi | \chi_{1} > + sin \phi | \chi_{2} >
and
\widehat{U_{\phi, \textbf{k}}} | \chi_{2} > = -sin \phi | \chi_{1} > + cos \phi | \chi_{2} >
then he writes
\widehat{U_{\phi, \textbf{k}}} | \Psi_{\theta} > = \widehat{U_{\phi, \textbf{k}}} (cos \theta | \chi_{1} > + sin \theta | \chi_{2} > ) =
then he simply rearanges:
= cos \theta \widehat{U_{\phi, \textbf{k}}} | \chi_{1} > + sin \theta \widehat{U_{\phi, \textbf{k}}} | \chi_{2} > )
and then he substitues the result \widehat{U_{\phi, \textbf{k}}} | \chi_{1} > and \widehat{U_{\phi, \textbf{k}}} | \chi_{2} > from above and that gives the result from the book.
My question is:
1) why is he using this procedure instead of simple matrix multiplication?
2) why is Matrix multiplication wrong?
3) why does the rotation matrix in the book look exactly like the transposed version of the one in wikipedia article (and any other article I could find)
4) How did the professor calculate the effect of the operator on the base (i.e. \widehat{U_{\phi, \textbf{k}}} | \chi_{1} >)
I've been tormented by this for a week now, any input is appreciated...
This is most probably a problem of active and passive coordinate transformations.
Basically, if you rotate your coordinate axes one way, then the new coordinates of a vector are obtained by rotating the old coordinates in the opposite direction. This is a constant pain in the rear that creeps up every time you do coordinate transformations.
This explains why the rotation matrix you give in the first post has the opposite sign of theta than the one on the Wiki page linked in the second post.
http://en.wikipedia.org/wiki/Active_and_passive_transformation
http://arxiv.org/abs/1106.4446 section 1.5 (very brief)
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
