Saddle point in trapping region
  • Thread starter Thread starter Appaloosa
    Point
The discussion revolves around saddle points in a 2D trapping region, where all trajectories on the boundary lead inward. The index theory suggests that the index of this region is +1, indicating that the sum of indices of fixed points inside must also equal +1. It is proposed that two unstable fixed points and a saddle point can coexist within this trapping region. The user seeks clarification on whether limit cycles must exist around the unstable fixed points or if all trajectories converge to the saddle's stable manifold. The inquiry highlights a need for better visualization and understanding of the topology involved in nonlinear systems analysis.
Appaloosa
hi all,
i have a question regarding saddle points. I'm looking at a 2D system which has a trapping region, all trajectories on the boundary point in. from strogatz's book on nonlinear systems I've read about index theory and so as i understand it the index of this region is +1 and the sum of the indices of any fixed points inside that region should also = +1. i understand that stable and unstable fixed points have index +1 whilst saddle points have index -1.
presumably this mean that it is possible for two unstable fixed points and a saddle to exist within this trapping region. i can't really visualize this topology however and I'm trying to work out whether limit cycles would have to exist about the two unstable fixed points or if all trajectories some how end up on the stable manifold of the saddle and are attracted to the saddle point? I'm pretty new to nonlinear systems analysis so I've probably misunderstood something somewhere which would explain which of these two scenarios actually occurs. hopefully someone can point me in the right direction?
Mathematics news on Phys.org
Those examples (of vector fields) can always be visualized by some drawings. I'm not sure what index in this context is, but it seems pretty obvious that saddle points relate to unstable equilibria.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
