Driving requirement of a typical ear phone of small walkman or IPOT
  • Thread starter Thread starter yungman
To create a simple battery amplifier circuit for a guitar to drive headphones, understanding the typical input impedance and voltage is crucial. Most headphones fall into two categories: high impedance (around 600 ohms) and low impedance (typically 30 to 100 ohms, with 50 ohms being common). Low impedance headphones are preferred for their louder output at the same voltage level. A standard op-amp may not suffice for driving these headphones effectively, indicating the need for a more robust solution. The discussion emphasizes the importance of matching the amplifier to the headphone's impedance for optimal performance.
yungman
I want to make a quick and simplest little battery amplifier circuit to amplifier the guitar to drive a headphone of a walkman or IPOT type where people wear to do workout or walking. What is the typical input impedance and input voltage.
I don't need high quality sound, just amplifier the signal of about 1mV to 2mV. Can I typical op-amp be used?
Thanks
Most headphones are one of two types.
"High impedance" phones have a standard impedance of 600 ohms. "Low impedance" phones are usually around 50 ohms, but could be anything between say 30 and 100.
Cheap headphones tend to be low impedance, because they "sound louder" driven from the same voltage level.
Thanks for the reply. Sounds like I need more than a common op-amp to drive it.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
