Why Does the Tube's Velocity Become Zero After Collisions?
  • Thread starter Thread starter ZxcvbnM2000
    Space
The discussion revolves around understanding why the velocity of a tube becomes zero after collisions involving two objects, A and B. Participants analyze the conservation of momentum, concluding that when considering the tube as part of the system, its velocity must indeed be zero after the interactions. Calculations show that the momentum before and after the collisions balances out, leading to the conclusion that the tube does not move. There is confusion regarding the distances covered by objects A and B, but it is clarified that this does not impact the overall velocities. Ultimately, the key takeaway is that the conservation of momentum dictates the tube's velocity remains zero post-collision.
ZxcvbnM2000
I solved questions a) and b) no problem but the thing is that in c)
i said that B will hit the end first so at first the tube will move with a speed Vtube1 ( Vb=x/t).So t=23.25s . After some time which i found to be 47.17 s , object A will hit the other end so the tube will now move by δV = Va-Vb .
But in the solutions it says that the tube's velocity will be zero!
can you please explain ?!
Hi ZxcvbnM2000! :smile:
How can it take 23 s to go only 1 m ? :confused:
A will hit first.
(It would help in future if you show all your calculations at the start.)
what about conservation of momentum?
Explosion (system of objects A&B) : 0 = 0.8*1 + 3* ub so ub = -0.26 m/s .
Object A : Ma*ua = (Ma+Mtube)*Vtube <=> Vtube = 0.0615 m/s
Object B : Mb*ub=(Mb+Mtube)*V'tube so V'tube=-0.052 m/s
And because this is space we're talking about the movement is linear so V=x/t for each object and we can find the times until they hit the ends.
What do you mean conservation of momentum ?
This is really not intuitive for me!
So you are saying that if we consider the tube as system how can we prove that it won't move ?
A yes; B no, because you need to use the new velocity and mass after A collides with the tube
if we consider the whole thing as the system, yes :smile:
Momentum Conservation between ( A&Tube) & B
so mb*ub + (ma + mtube)*V = (ma +mb +mtube)*V'
but we know that ma*ua + 0 =(ma +mtube)*V , also -maua=mbub
so V' = 0 right ?? So it won't move.But i have a question as The tube is going to the left after colliding with A and B is going to the right doesn't this mean that B will cover less distance ??
quicker would be to compare before and after for the whole thing :wink:
yes, but so what? it won't affect the velocities, and the question doesn't ask for it! :smile:
