Total Elastic Potential Energy 2
To find the speed of block B as it passes through its equilibrium position, the total mechanical energy must be calculated correctly. The energy stored in the springs when the block is moved 0.5 meters is equal to the elastic potential energy (EPE) at that position. The extensions in both springs must be accurately determined, as they affect the total energy. The total mechanical energy at the displaced position should equal the sum of kinetic energy (KE) and EPE at the equilibrium position. Ensuring correct calculations will prevent obtaining the square root of a negative number, which indicates an error in the energy balance.
kingyof2thejring
I need to know how to go about finding the speed.
A block B of mass 5 kg is fastened to one end of each of two springs. The other ends of the springs are attached to fixed points A and C, 4 metres apart on a smooth horizontal surface, as shown in the diagram.
Spring AB has natural length 2 metres and modulus of elasticity 30 N, while BC has natural length 1 metre and modulus 40 N (you may assume that the springs meet at the centre of B).
If the block is moved 0.5 metres towards C from its equilibrium position and then released, determine its speed as it passes through its equilibrium position.
this is what i have tried
Energy in string when moved 0.5m = total mech energy before the 0.5 movement
E= 30*(0.5)^2/(2*2) = 1.575 J
KE= 1/2*5*v^2 = 5/2*v^2 J and
E in string 30*(3/8)^2/2*2 = 7.93 J
7.93 + 5/2v^2 = 1.875
this leads me to taking square root of a -ve number
could someone help me!
thanks in advance
I'm going to assume this is a follow-up to the question I did https://www.physicsforums.com/showthread.php?t=61316".
The springs already had an extension at the equilibrium position, so when you move it box towards C, the extension will change.
The extension in AB (x) is now: 0.5 + 8/11 = 27/22
The extension in BC (y) is now: 3/11 - 0.5 = -5/22 (i.e. compression)
Calculate the total mechanical energy at that point (which is only EPE). This should equal the total mechanical energy at the equilibrium position (which is KE & EPE).
It's important that you calculate the total energy. You shouldn't get the square root of a negative number. :smile:
cheers i can dig that
