Three problems on Complex Analysis
carlosbgois
1)Show that (1-i)^{2}=-2i then evaluate (1-i)^{2004}+(1-i)^{2005}
2)Prove that every complex number with moduli 1, except z=1, can be put in the form \frac{a+i}{a-i}
3)Let m and n be positive integers without a common factor. Define z^{m/n}=(z^{m})^{1/n}, and show that z^{m/n}=(z^{1/n})^{m}
1) I solved (1-i)^{2}=-2i by expanding, and then solved in the polar form, that is, (1-i)^{2}=(\sqrt{2}(cos(-pi/4)+i*sin(-pi/4))^{2}=2(cos(-pi/2)+i*sin(-pi/2)=\sqrt{2}(1-i), hence, \sqrt{2}(1-i)=-2i. Then I stopped because something's wrong, isn't it?
2)Let z=x+yi. Letting x+yi=\frac{a+i}{a-i} I can obtain the following equations: xa+y=a; ya-x=1, which, solved simultaneously, yields a=\sqrt{\frac{1+x}{1-x}}, then I got stuck.
3)I've just used DeMoivre's with z in polar form and particular properties of real numbers to invert the powers, but idk if that's correct.
Many Thanks
Many Thanks
Yes, something is wrong.
cos(±π/2) = 0
For 1 , you can look at multiplication as multiplying the respective moduli and
adding the arguments (mod 2pi if necessary). For 2, it seems you can just solve
for a in a single equation, to have a in terms of x,y ; after all, z seems to be given
in terms of x and y.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
