Need explanation on how electrons and electricity work
Electrons in a ruler can be transferred to or from hair when rubbed, leading to static electricity. Atoms do not "need" free electrons, but they can lose or gain them, which affects their charge. Non-conductive materials like wood have tightly bound electrons, making it difficult to remove or add them, and they are not unstable due to this. The difference in charge when rubbing materials is due to varying energies required to gain or lose electrons, and the temporary attraction of charged objects diminishes as they lose charge to their surroundings. Understanding these principles clarifies how electricity and electron movement function in different materials.
SC0
Hey guys
I'm a new member and I will be mostly asking questions :P
Anyways ...
Physics subjects in my school are about electricity now and my teachers aren't very good, so I can't clearly understand what they're saying.
To get to the bottom line, our lesson was about electrons and electricity.
I understand that when I rub a ruler on my hair - for example - it would be charged and therefore it can attract scraps of paper.
My questions are :
1.Where do electrones go in the ruler ?
2.Free electrones that conduct electricity, does the atom need them ? if not then why did the atom take them in the first place ?
3.Non-conductive materials such as wood, as I understood they don't conduct electricity because their atoms need to be filled with electrones so they can be stable, is that right ? If so, are atoms in the Non-conductive materials unstable ? and shouldn't they after awhile of charging they will be full and will therefore conduct electricity ?
4.Some materials when rubbed will get positive charges and some will get negative, why ?
5.After charging a ruler it would attract for a few minutes then it will stop, why ?
Could someone please explain everything to me ?
Thanks.
To your hair (or maybe the other way round, I do not know), so your hair gets charged a bit, too.
Define "need".
An uncharged atom has the same number of protons (positive charge) and electrons (negative charge). However, especially in solid objects, you can remove or add electrons - this requires some energy, but it is possible. The number of removed or added electrons per atom is usually extremely small - your ruler might have something like one additional (or one missing) electron per 1 trillion atoms.
No. But the electrons are bound to their atoms, and it requires a lot of energy to remove an electron from an atom (or add one).
See question 2: The amount of electrons you can add as electrostatic charges is extremely small. Every solid object (and even gas) is a conductor, but some of them are really bad.
That is a very good question, and there is still research ongoing about this question. The general idea is that for some materials, it is easier (requires less energy) to take additional electrons, while other materials tend to give away electrons.
Nothing is a perfect insulator, so the ruler slowly loses its charge via your hand, paper, the air and whatever else is close to it.
2.Free electrones that conduct electricity, does the atom need them ? if not then why did the atom take them in the first place.
It should be worth noting that to be an atom, it needs the same number of electrons as it has protons and thus has no charge, and if it loses or gains elctrons, the atom becomes an ion (effectively a charged atom). conductors are usually metal, and the bonds in metal are electrostatic - between the positive metal ions, and the delocalised electrons that are 'released' when the atom becomes an ion.
Ok thanks guys :)
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
