Calculate approximately G-force applied on Car shock absorber
To calculate the G-force on car shock absorbers using accelerometers, the scenarios involve a car weighing 2000kg driving over bumps of 5cm and 30cm at speeds of 110km/h and 50km/h, respectively. The calculations consider the bump as a spring, using the formula for acceleration based on angular frequency and displacement. However, the initial calculations yield abnormally high G-force values, indicating a potential miscalculation or misunderstanding of the spring constant. The rise/run ratio of the bumps significantly influences the G-force experienced, with sharper bumps producing higher G-forces than gentler slopes. Accurate calculations require careful consideration of these factors to achieve realistic G-force estimates.
ELEFANTOMET
I have to do some dataacquisition from a car with some accelerometers.
4 accelerometers is placed on the wheels before the shock absorber. And i need to calculate the maximum applied G-force on the accelerometers.
Just an approximately value, not taking in account the type of wheel, airpressure in wheel etc.
Scenario 1:
Steady speed of the car driving on normal tarmac is 110km/h.
Weight of car is 2000kg
The car is driving over a small bump with a height of 5cm
Scenario 2:
Steady speed is 50km/h
Weight 2000kg
The car is driving over a regular speedbump, approximately height of 30cm
Seeing the bump on the wheel as if was a regular spring, i would calculate acceleration from
A=5cm
ω=sqrt(k/m) (not knowing the spring constant, i just took some samples from 0-500Hz as a value, what's realistic here?)
a=-ω^2*A*cos(ω*t)
with a.max being -ω^2*A
and then divide final max acceleration with 9.8m/s^2. But this seem to give me abnorm large value of g-force.
Any help, to how to calculate this the right way?
The rise/run ratio of your bumps will have some determination of your G force.
A slightly sloped bump gives less G force than a sharp bump, due to Ft.
A 30 cm bump - this is a regular sped bump height?
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
