Fortran Problem on reading dataset with variable decimal places as it is using fortran
The discussion centers on reading and writing datasets in Fortran while preserving the original decimal formatting. The user initially faced an issue where the output data was altered to three decimal places due to the specified format in the WRITE statement. It was clarified that when data is read into a binary format, the original decimal precision is lost. To maintain the original formatting, it was suggested to read the data as character strings, convert them to numeric values for calculations, and then write the original character strings back to the output file. The user successfully implemented this approach after understanding the advice given, resolving the formatting issue.
fortranuser
Hi all,
I have attached my text file(tab delimited).
I am planning to read those dataset into real array of (30,38). The dataset has variable decimal places like 312.66, 0, 535.696 ,456122.758.
With the following codes,
READ(12,*)((X(I,J),I=1,30),J=1,38)
WRITE(*,20)((X(I,J),i=1,30),j=1,38)
20 format(58(f12.3x,2x))
I was able to read the original txt file and stored those data into real array of (30,38) and then it was written in new txt file.
The problem is that because of the format(58(f12.3x,2x)) the data set in latter file got changed(now each data set has 3 decimal places)
Is it possible to make data in latter file similar to original text file
Technology news on Phys.org
When you read the original data, it's converted from decimal to binary and stored as binary inside your program. The binary data has no "memory" of the original number of decimal places.
If you really need to preserve the original number of decimal places on output, you should read the data as character strings, then convert the strings to binary numeric data using Fortran's "internal read" technique. Do your calculations using the converted data, but write the original data back out using the character strings.
hi jtbell,
Thanks for writing me. I have written the program just to test which is as follow
PROGRAM CHAR_ARRAY
character(10):: data
real::a
read(*,*)data
read(data,*)a
print*,a
END
I gave 45.2 to data and output was 45.200001.
so still the problem is same.
Well, what jtbell said was to write the original data back out by using the original 'character' variable you read it into...not using your internal 'real' variables.
hi gsal
I carefully read to jtbell again and finally understood what you and he wants me to do.
Thanks both of you.Problem is no more.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
