Charged particles through magnetic field
Charged particles in the Large Hadron Collider (LHC) are accelerated through a series of superconducting magnet rings, which primarily serve to deflect their trajectory into a circular path rather than increase their speed. The actual acceleration occurs through electric fields strategically placed along the particle's path, allowing for repeated "kicks" as the particles pass through these fields. Initially, protons are accelerated by a linear accelerator before entering the circular path. The energy of the particles at the point of collision depends on their speed, which is increased through these electric fields. Ultimately, the collisions at high speeds reveal new particles, confirming the effectiveness of this acceleration method.
Crazymechanic
I have a question that I want to verify , so that i know is my understanding about how the LHC works.
So basically there is this charged particle being thrown into a huge lone tube consisting of superconducting magnet rings and while each of the magnet rings has it's magnetic field traveling around a circle the particle going perpendiculary through many of those gets it's boost more and more and then in the end when two of these tubes with particles traveling through them get together from opposite sides the particle speeds are great enough so that a collision reveals new particles at certain energy's , I guess depending on how fast they were accelerated.
So it's basically a huge Coil gun and the particle is the metal thing or bullet traveling through that gun being kicked by the magnetic fields so that it takes up speed and so has more energy in the end when there is a collision?
Thanks for answers.
Actually, magnetic field's task is just to deflect proton's trajectory in order to make it circular. As you know, in fact, magnetic force is always perpendicular to the velocity of the charged particle, so it can't increase the magnitude of its velocity but it can deflect it.
If I remember well, usually linear acceleration is achieved thanks to electric fields placed in some fixed zones of the circular path. If you choose the frequency of this electric fields correctly you can "kick" the particle every time it passes trough the field.
I think at LHC the first acceleration is give by a linear accelerator which enters the protons into the circular path and then subsequent accelerations are obtain with many different kind of electric fields.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
