Fortran Fortran: determine the horizontal distance of a ball
The discussion focuses on troubleshooting a Fortran program designed to calculate the horizontal distance a ball travels. Key errors identified include the use of the wrong operator for exponentiation, incorrect integer arithmetic for the constant (1/2), and improper variable declarations, particularly for arrays and types. The program also contains an infinite loop that prevents it from functioning correctly after user input. Additionally, the calculation of distance should not require a READ statement since it is computed within the program. Overall, the suggested fixes resolved the initial errors, but further adjustments are necessary for proper execution.
CCguru
Im writing a program to determine the horizontal distance of a ball but getting this error:
Y(t)=Y0+VY0*t+(1/2)*g*t^2
Error: Unclassifiable statement at (1)
Distance=(X(t))^2+(Y(t))^2
Error: Unclassifiable error at (1)
My code is as follows:
PROGRAM as_the_ball_is_thrown
IMPLICIT NONE
INTEGER::Y0, X0, V0, g, theta, t
CHARACTER::Distance, VY0, VX0, X(t), Y(t)
X0=0
Y0=0
V0=20
g=9.81
WRITE(*,*) "Please enter amount of time the ball traveled"
READ(*,*) t
WRITE(*,*) "Please enter the angle to which the ball was thrown"
READ(*,*) theta
DO
X(t)=X0+VX0*t
VX0=V0*COS(theta*3.14159/180)
VY0=V0*SIN(theta*3.14159/180)
END DO
WRITE(*,*) "The horizontal distance the ball traveled is"
READ(*,*) Distance
WRITE(*,*) "meters"
END PROGRAM as_the_ball_is_thrown
Can anyone tell me why this is wrong?
Thanks!
Technology news on Phys.org
^ is not the Fortran operator for "raise to a power". It should be **.
Also (1/2) will be evaluated in integer arithmetic since 1 and 2 are both integers, and the integer division will give 0 which is not what you want. The best fix is to replace (1/2) by 0.5.
Declaring Y0, X0, V0, g, theta, t as INTEGER is probably not a good idea, especially since you then try to set g = 9.81 (which will actually set it to 9).
In addition to what AlephZero said, you have problems with your declarations for X(t) and Y(t). For one thing, this is not how you declare arrays. For another thing, why are these character-type variables? That doesn't make any sense.
Awesome thanks! That fixed all the errors. Now for some reason the program just stops and doesn't print anything after a person enters the angle. Do you guys know why?
There are a couple things wrong.
1) You have what I believe is an infinite loop below where you shouldn't be using a loop at all. OTOH, if you are trying to set the values of an array to certain values, maybe that's what you're trying to do. If that's the case, the following code won't work, because array indexes have to be integer values 1, 2, 3, and so on.
It's hard to tell what you're trying to do, though.
Code:
DO
 X(t)=X0+VX0*t
END DO
2. Distance is computed, so you don't need to READ it, just WRITE it.
Code:
 READ(*,*) Distance
WRITE(*,*) "meters"
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
