How Can Newton's Laws Derive the Plateau Equation for Soap Films?
Sasha86
The Plateau equation (minimal surface of a soap film) can easily be derived from variational principle. We want to minimize the area of the soap film,
<br /> S = \int \sqrt{1 + z_x^2 + z_y^2} \, \mathrm{d}x \, \mathrm{d}y<br />,
and through Euler-Lagrange equation we get the Plateau equation,
<br /> \frac{\partial}{\partial x} \left( <br /> \frac{z_x}{\sqrt{1 + z_x^2 + z_y^2}}<br /> \right) +<br /> \frac{\partial}{\partial y} \left( <br /> \frac{z_y}{\sqrt{1 + z_x^2 + z_y^2}}<br /> \right) = 0.<br />
I'd like to derive this equation from Newtons law.
<br /> z_x = \frac{\partial z}{\partial x} \\<br /> z_y = \frac{\partial z}{\partial y} \\<br /> z_{xx} = \frac{\partial^2 z}{\partial x^2} \\<br /> z_{yy} = \frac{\partial^2 z}{\partial y^2}<br />
\gamma - surface tension
I'll write the forces for a small element of the film, whose projection to plane z = 0 is a square \mathrm{d}x \, \mathrm{d}y. Sum of the forces on each element must by Newton be 0. Area of the element is \mathrm{d}S = \mathrm{d}x \, \mathrm{d}y \sqrt{1 + z_x^2 + z_y^2} = \sqrt{\mathrm{d}x^2 + \mathrm{d}z^2} \sqrt{\mathrm{d}y^2 + \mathrm{d}z^2} \frac{\sqrt{1 + z_x^2 + z_y^2}}{\sqrt{1 + z_x^2} \sqrt{1 + z_y^2}}.
The work needed to increase a surface is \mathrm{d}W = \gamma \mathrm{d}A (F \, \mathrm{d}x = y \, \mathrm{d}x for a simple square). Imagine I want to stretch the element in the x direction. Then the element stretches by \mathrm{d} \left( \sqrt{\mathrm{d}x^2 + \mathrm{d}y^2} \right) and the force needed to overcome the tension is \gamma \, \mathrm{d}y \, \sqrt{\frac{1 + z_x^2 + z_y^2}{1 + z_x^2}}. I'll only be interested in z component of the force so I need to multiply it by \frac{\mathrm{d}z}{\sqrt{\mathrm{d}x^2 + \mathrm{d}z^2}}.
Similarly for stretching in y direction.
Now I'll mark with \mathrm{d}_x a small diference between x and x + \mathrm{d}x and similarly for y. I then write the sum (over four sides of the small element) of the forces in z direction on the small element,
<br /> \mathrm{d}_x \left(<br /> \gamma \, \mathrm{d}y \, \frac{\sqrt{1 + z_x^2 + z_y^2}}{1 + z_x^2} z_x \right) +<br /> \mathrm{d}_y \left(<br /> \gamma \, \mathrm{d}x \, \frac{\sqrt{1 + z_x^2 + z_y^2}}{1 + z_y^2} z_y \right) = 0.<br />
Divide the expression bx \gamma \, \mathrm{d}x \, \mathrm{d}y and get,
<br /> \frac{\partial}{\partial x} \left( z_x \frac{\sqrt{1 + z_x^2 + z_y^2}}{1 + z_x^2} \right) +<br /> \frac{\partial}{\partial y} \left( z_y \frac{\sqrt{1 + z_x^2 + z_y^2}}{1 + z_y^2} \right) = 0,<br />
which isn't the Plateau equation.
Also, if I write the forces in the x direction I get,
<br /> \mathrm{d}_x \left(<br /> \gamma \, \mathrm{d}y \, \frac{\sqrt{1 + z_x^2 + z_y^2}}{1 + z_x^2} \right) = 0,<br />
which suggests that the expression between the braces depends only on y. Take this into account in the upper equation and get,
<br /> \frac{\sqrt{1 + z_x^2 + z_y^2}}{1 + z_x^2} z_{xx} +<br /> \frac{\sqrt{1 + z_x^2 + z_y^2}}{1 + z_y^2} z_{yy} = 0.<br />
This is even worse. What am I missing?
Hello, and welcome to PF!
A couple of things that I noticed that don't seem correct to me, but maybe I'm just not following your work.
First, you have the following expression for the force:
Sasha86 said:
...the force needed to overcome the tension is \gamma \, \mathrm{d}y \, \sqrt{\frac{1 + z_x^2 + z_y^2}{1 + z_x^2}}.
If this is the force on one edge of the surface element, then I would think the magnitude of the force would be ##\gamma## times the length of the edge, which doesn't seem to be what you have.
Second, I don't think your expression for getting the z-component of the force is correct:
The force will point in a direction that is tangent to the surface and also perpendicular to the edge. In general, the force vector will have nonzero x, y, and z components. So, the factor for finding the z-component will be more complicated than your expression.
That's how I see it anyway.
Ah yes, I stupidly made an assumption that on x and x + \mathrm{d}x edges, where y = const., the forces don't have the y component. I then tailored my derivation around this assumption.
If I now try it again.
Force on x and x + \mathrm{d}x edges is \gamma \sqrt{\mathrm{d}y^2 + \mathrm{d}z^2}. This force is tangent to the surface and perpendicular to the edge. The normal to the surface is \mathbf{n} = \left( -z_x, -z_y, 1 \right) (I'm not normalizing the vectors here) and the edge has the direction \mathbf{s} = \left( 0, 1, z_y \right). The force then must be perpendicular to both this vectors and has the direction, \mathbf{s} \times \mathbf{n} = \left( 1 + z_y^2, -z_x z_y, z_x \right). The z component of the force is then proportional to \frac{z_x}{\sqrt{\left( 1 + z_y^2 \right)^2 + z_x^2 z_y^2 + z_x^2}} = \frac{z_x}{\sqrt{1 + z_y^2} \sqrt{1 + z_x^2 + z_y^2}}.
Similarly for the other two edges.
Similarly as before I sum the forces over the edges and with \mathrm{d}_x mark a small difference between x - \mathrm{d}x (force of the left neighbouring element) and x + \mathrm{d}x (force of the right neighbouring element). The forces are then,
<br /> \mathrm{d}_x \left( \gamma \mathrm\, {d}y \, \frac{z_x}{\sqrt{1 + z_x^2 + z_y^2}} \right) + \mathrm{d}_y \left( \gamma \mathrm\, {d}x \, \frac{z_y}{\sqrt{1 + z_x^2 + z_y^2}} \right) = 0.<br />
Divide this by 2 \gamma \, \mathrm{d}x \, \mathrm{d}y and you get the Plateau equation.
Thank you for your input. It's been very helpful.
That all looks correct to me. Good.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
