How does momentum dumping work on the Hubble Space Telescope?
  • Thread starter Thread starter Fi-reefly
    Momentum
Momentum dumping on the Hubble Space Telescope involves using magnetic torque rods to manage the saturation of reaction wheels. When these wheels reach saturation, the magnetic torquers create a magnetic field that interacts with the Earth's magnetic field, allowing the spacecraft to adjust its attitude without losing control. The process requires changing the speed of the wheels in response to the torque generated, ensuring that the spacecraft maintains a constant orientation. Electromagnets are activated to facilitate this adjustment and must be turned off once the wheels have spun down to prevent oversaturation. This mechanism is crucial for the telescope's operational stability and precise positioning.
Fi-reefly
I've been reading about Hubble Space Telescope and the concept of momentum dumping done by the magnetic torque rods. I understand that when the reaction/momentum wheels are saturated, the magnetic torquers (magnetorques/magnetic torque rods, there were a lot of names for them !) must be used to remove some of the momentum.
However, I'm confused by the process of momentum dumping. How is it done?
Does anyone have a link that explains it more in depth?
{or may be willing to explain it here}
Thanks!
Astronomy news on Phys.org
Easy answer is that the wheels change speeds in reaction to various torques to maintain a constant attitude. The speed they're currently spinning at doesn't matter. It's the change in speed that controls the attitude.
So, if the wheels are spinning in a positive direction, you create a torque that the wheels need to change speed in a negative direction to counteract.
In this case, you turn on electromagnets that create a magnetic field around the spacecraft . The magnetic field of the spacecraft will naturally align itself with the Earth's magnetic field if no action is taken to stop it. Except the spacecraft 's attitude control system's job is to maintain a constant attitude, so it changes the wheel speeds instead of letting the spacecraft change its attitude. And then, obviously, the electromagnets have to turn off as soon as the wheels have spun down so they don't saturate the opposite direction, at which point the spacecraft actually would start to move to align itself with the Earth's magnetic field.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
