Associativity of operators in quantum mechanics
p6.626x1034js
What is the correct interpretation of
< \frac{\partial {A}}{\partial t} >, where A is an operator?
for a wave function \phi and operator A,
<A> = \int_{V}\phi^{*}(A\phi)dV
I thought it could mean
< \frac{\partial {A}}{\partial t} > = \int_{V}\phi^{*}\frac{\partial}{\partial t}(A\phi)dV
but then again it might mean
< \frac{\partial {A}}{\partial t} > = \int_{V}\phi^{*}(\frac{\partial A}{\partial t})(\phi)dV.
I read an article saying that operators are associative. But, when I think about the operators t and \frac{\partial}{\partial t}, then,
\frac{\partial}{\partial t}\left(t\phi\right) = t\frac{\partial\phi}{\partial t} + \phi \neq \left(\frac{\partial t}{\partial t}\right)\phi = \phi
any thoughts?
The d/dt is not an operator in the normal sense. A(t) is interpreted as a set of operators which depend on a parameter, t. The derivative of this A(t) wrt the parameter is defined by means of a limiting procedure always in the presence of vectors in the domain of all A(t).
\frac{d A(t)}{dt} \psi = \lim_{t\rightarrow 0} \frac{A(t)\psi - A(0)\psi}{t}
The expectation value is then simply \left\langle \phi, \frac{dA(t)}{dt}\phi\right\rangle
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
