Minimum amount of power need to charge a li-ion battery
Charging a small lithium-ion battery of 3.4 V and 2100 mAh requires careful management of power to avoid safety hazards, as improper charging can lead to explosions or fires. Specialized chargers are essential for handling the unique charging cycles of li-ion batteries, which include phases of constant current and voltage adjustments. A recommended starting charge current is 1 amp, but it is not strictly necessary to adhere to this figure, as the key is reaching the battery's float voltage without causing damage. There is no established minimum current level for charging, although extremely low currents may be impractical for effective charging. Understanding the charging process is crucial for safe and efficient battery management.
drprofesorxjr
What is the minimum amount of power needed to charge a small lithium ion battery of 3.4 V and 2100 mAh?
A li-ion battery requires a special charging cycle!
It is DANGEROUS to just connect it to a power supply!
Look at the site http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries if you want to learn more.
Most li-ion chargers have specialized charging circuits that take care of security, overvoltage, short circuits and such.
Be VERY careful with li-ion, they explode, they burn, they are not toys.
Thanks for the reply. I mean what is the minimum amount of current that can be used to charge a small li-ion battery?
I would recommend you read through the link I sent. It specifies a charge current of 1 amp in the beginning. When the battery reaches its voltage the current is decreased until you see a special drop in the voltage across the battery.
But read from the link and learn. Those guys know what they are talking about :)
You don't have to charge with 1A or whatever. I also doubt the 'constant-current' phase of the charge cycle really has to be constant. The point, as I see it, is to charge the cell with a current source (whatever it may be) until it reaches its float voltage at which point any further increase in voltage might – and eventually will – damage the cell. I can't see why there would be an inherent lower limit on the charge current.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
