Bipolar Junction Transistors - How does one read the datasheet?
The discussion focuses on interpreting the datasheet for a PNP Bipolar Junction Transistor (BJT), specifically regarding the hFE values listed under ON CHARACTERISTICS. It highlights that the most common hFE value is around 100, but there is significant variation, which suggests that circuit designs should accommodate this variability or involve testing individual devices. The test voltage VCE of -1.0V raises questions about the range of applicable voltage drops, indicating that the hFE variation with collector current (IC) is more critical than that with VCE. Users are encouraged to consult additional datasheets for comparative analysis of IC versus VCE to understand the implications of these variations. Proper interpretation of these parameters is essential for reliable circuit design and functionality.
d.arbitman
In particular, I am looking at a datasheet of a PNP BJT:
http://www.fairchildsemi.com/ds/2N/2N3906.pdf
I noticed that in the ON CHARACTERISTICS sub-heading, there were multiple h_{FE} values. I'm wondering how I could extract any meaningful information from that since the most common h_{FE} value is ~100. I also don't understand why the test V_{CE} value is only -1.0V; shouldn't there be a wider range of applicable voltage drops from collector to emitter. How would I interpret the information provided to me in that section?
There is a wide spread of hFE for this device. Furthermore, hFE also varies with collector current (there's a graph showing this). This tells you that whatever circuit you use, that circuit should be designed to be tolerant of a wide variation of hFE. Either that or you must individually test a handful of devices and pick the one with the highest gain. (Not advisable, as repair and replacement may well see the circuit not function.)
I think you'll find that the variation of hFE with VCE is of the same order, or overshadowed by, the variation of hFE with IC. You can judge for yourself if you unearth a plot of IC versus VCE on another manufacturer's datasheet: the more horizontal the lines, the less the variation.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
