How Do You Convert a Complex Spiral Equation from Polar to Cartesian Form?
  • Thread starter Thread starter Rohitpi
    Cartesian
To convert the complex spiral equation |z| = arg(z) from polar to Cartesian form, the discussion emphasizes using the angle θ as the parameter. The parametric equations derived are x = θ cos(θ) and y = θ sin(θ), where r = |z| = arg(z) = θ. The original poster expressed confusion in finding these equations and acknowledged the need for clarity in their query. The Cartesian equation was noted to be as simplified as possible given the context. Overall, the conversation highlights the importance of defining parameters clearly when converting between forms.
Rohitpi
I'm volunteering in a summer school for year 12 students in my area, and have to teach them a few topics. I've been struggling to get the parametric equations from this.
Sketch: |z| = \arg(z)
So I thought that the obvious way to explain it to them would be to say: "that as the magnitude of z increases (ie. distance from the origin) the greater the angle becomes, thus producing a spiral" and I can draw it on the whiteboard.
Upon attempting the Cartesian equation, I got a bit stuck:
|z| = \arg(z)
\sqrt{x^2 + y^2} = \tan^{-1}(\frac{y}{x})
\tan{(\sqrt{x^2 + y^2)}}=\frac{y}{x}
y=x\tan{({\sqrt{x^2 + y^2}})}
And that is where I get stuck unfortunately. Any thoughts/solutions on how to proceed in finding a Cartesian and/or parametric equations?
(sorry if this doesn't make sense, I haven't done any maths since year 12 haha as I study med atm :/ I miss maths!)
Mathematics news on Phys.org
You titled this "Cartesian equations" and refer to the Cartesian equation in the body but also ask for parametric equations. Which do you want?
You haven't said what parameter you want to use. I would recommend the angle \theta= arg(z). Then x= r cos(\theta) and y= rsin(\theta) while r= |z|= arg(z)= \theta so the parametric equations are just x= \theta cos(\theta), y= \theta sin(\theta).
As for the Cartesian equation, I think you have it about a simple as you are going to get it.
Ah, thanks! Sorry about the title, I should have included both Parametric and Cartesian. The issue I had with the parametric was as you alluded to, I actually didn't know where to start (hence the query was vague).
Thanks a lot! :)
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
