What is an effective approach to proving that interior points are open?
  • Thread starter Thread starter pokemonsters
    Interior Points
pokemonsters
For S \subset Rn, prove that S° is open.
S° are all interior points of S.
My class has only learned how to use balls to solve these types of problems (no metric spaces). So I need to choose an ε > 0 so that Bε(x) \subset S°, where x is any arbitrary point in S°. To show this is true, let y \subset Bε(x) be arbitrary. (then I don't know how to progress further...how do I show that the neighbourhood contains only points in S°?)
Start by choosing an arbitrary x \in S^o. By definition this is an interior point of S, so there exists \epsilon > 0 such that B_\epsilon(x) \subset S. Now, if you can show that every point y \in B_\epsilon(x) is an interior point of S then you're done. To do this, it certainly suffices to show that you can fit a smaller ball B_\delta(y) around y which is entirely contained within B_\epsilon(x), because then you will have y \in B_\delta(y) \subset B_\epsilon(x) \subset S. Try drawing a picture to see how to define \delta, the radius of the smaller ball.
Thank you, I did not notice that you can put another ball inside the ball to make the proof work.
Using this, I was able to make a series of inequalities using the triangle inequality, and managed to prove that y \in B_\delta(y) \subset B_\epsilon(x) \subset S.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
