Distance dependence in Ampere's force law
  • Thread starter Thread starter Sunfire
    Force Law
Ampere's force law indicates that the force between two parallel conductors is independent of the distance between them, as expressed in the equation F=2ka(I1I2)/r. The force is measured in N/m, which reflects the force per unit length of the conductors rather than a total force. This distinction clarifies that while the distance (r) affects the force per unit length, the overall force remains constant for parallel conductors. The discussion highlights the importance of understanding the definitions and units involved in Ampere's law. Overall, the relationship emphasizes the unique characteristics of electromagnetic forces in this context.
Sunfire
Hello,
In the Ampere's force law
F=2ka\frac{I_{1}I_{2}}{r}
Ampere law,
the force between 2 parallel conductors doesn't seem to depend on the distance between them.
F is given in [N/m], instead of just [N]...
What is the rationale behind this?
Thank you.
Does it stem from the definition of Ampere
Reading some other threads on the subject helps... I see that the force is per unit of cable length, while r on the RHS is the distance betw the 2 cables, okay :)
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
