Automotive Are Battery Issues Hindering the Development of Automotive Power?
Battery issues are significantly impacting the development of automotive power, primarily due to high costs and long charging times. Current battery technology often lacks the longevity compared to traditional fuel sources like petrol, which can operate for days without refueling. These limitations hinder widespread adoption of electric vehicles and the overall advancement of automotive power systems. The discussion highlights a need for more research and articles addressing these challenges. Addressing these battery-related issues is crucial for the future of automotive power development.
Mohiden
Battery issues in Automotive!
Hi guys,
I'm required to write an essay about development of 'Automotive Power', with particular reference to the Batteries.
So, I'm looking for some current issues on the batteries related to its development!
Any idea?!
Thanks
What do you think some of the issues might be?
I think the major issue is the cost! Also the charging time takes long.
It doesn't last for that long where as the other power source such as petrol last for days.
But I'm trying to find some issues regarding it's development.
I'm wondering if anyone have an article talks about this! It will be really helpful.
I tried to look but couldn't find that much.
thanks
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
