What is a pure quantum state and a mixed quantum state?
rsaad
hi
what is a pure quantum state and a mixed quantum state? I looked up the internet but I did not quite understand. For pure quantum state I have read that they can't be written down as a mixture of other states? are entangled states pure states?
The distinction between 'pure' and 'mixed' applies to ensembles of quantum systems, not the possible states of individual quantum systems.
Consider the following examples. You have N spin 1/2 systems:
1. All of your spin systems are identically prepared in a S_z= +1/2 eigenstate. This is a pure ensemble.
2. All of your spins are identically prepared in the same linear combination of + and - Sz eigenstates. This is also a pure ensemble.
3. 25% percent of your spin systems are prepared like in 1 above. 75% are prepared in the state described in 2. This is a mixed ensemble.
Mathematically the difference is easily seen in terms of the density matrix \hat{\rho} of the ensemble if you are familiar with that idea. For a pure ensemble, the trace of the square of the density operator is a maximum at one: Tr(\hat{\rho}^2)=1. For any mixed ensemble the trace of \hat{\rho}^2 is less than 1. Also, for a pure state, the density operator is indempotent, i.e. \hat{\rho}^2=\hat{\rho} So, if you are able to write down the density matrix of the system, you have an easy way of determining whether a state is pure or mixed.
The "ensemble" can also consist of the systems that participate in the experiment when you run it multiple times. If you use a preparation procedure that puts the spin of a silver atom in the pure state ##|+\rangle## 1/3 of the time and in the pure state ##|-\rangle## 2/3 of the time, the spin of a single silver atom that's been subjected to that procedure is in a mixed state.
A state in general is defined as a positive operator of unit trace.
By definition a pure state is defined as an operator of the form |u><u|. It can be shown that any state can be written as a convex sum of pure states - but not uniquely. Non pure states are called mixed.
Check out;
http://en.wikipedia.org/wiki/Quantum_state#Mixed_states
Thanks
Bill
Thank you all! I understand it now.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
