Strange Differential Equation: Solving a Radical Splitting ODE
Bipolarity
Solve the following differential equation, with the initial-value y(2)=2.
y' = \sqrt{ \frac{1-y^{2} } { 1-x^{2} } }
This is a strange ODE. It is continuous when either both |x|<1 and |y|<1 or when both |x|>1 and |y|>1. (Both of the regions guarantee the existence and continuity of the derivative)
\frac{y&#039;}{ \sqrt{ 1-y^{2} } } = \frac{1 } { \sqrt{1-x^{2} } }
However, when you separate the variables (to solve it), the radical splits, causing the derivative to be defined only when both |x|<1 and |y|<1. The other region i.e. |x|>1 and |y|>1 is lost as a region in which a solution exists. This is strange.
By the existence theorem, that the function y'(x,y) is continuous when both |x|>1 and |y|>1 should guarantee the existence of a solution, yet separation of variables forces the loss of a solution in that region.
What then, is the (explicit) solution for that region, or how might I go about finding it?
I did end up finding the explicit solution to the IVP to be y = x but to do so I required the computation arcsin(2)-arcsin(2) = 0. This makes no sense.
BiP
sqrt(a*b)=sqrt(a)*sqrt(b) is true only for a,b>0, otherwise your operation is invalid in the real numbers. For |x|, |y|>1, you cannot split them like that - unless you use complex numbers.
y&#039; = \sqrt{ \frac{1-y^{2} } { 1-x^{2} } }
For |x|,|y|>1 you need
\frac{y&#039;}{\sqrt{y^2-1}} = \frac{1}{ \sqrt{x^2-1}}.
For the first case you need integrals of the form ##\int dt/\sqrt{1-t^2},## while for the second case you need ##\int dt/\sqrt{t^2-1}.##
OK thanks, so then how would the explicit solution be obtained when |x|,|y|>1 ?
BiP
Oh, of course, see Ray Vickson's post how to split the sqrt in this case.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
