Gravitational Time Dilation and Twin Paradox ?'s
In summary: I suppose bunching the underlying explanation of everything into time is reasonable if that was the underlying explanation but I do not think that's what gravitational time dilation is saying. In summary, the gravitational time dilation is a physical effect that affects time. The closer to a gravitational source the slower the time. The paradox is a thought experiment and is unlikely to actually occur, but it can be interpreted to mean that every particle in the universe slows down.
  • #36
PAllen said:
Each clock thinks its rate is 'right'. Lower one sees upper one fast; upper one sees lower one slow. This is not symmetric like relative motion in flat spacetime; however you still can't say which one is 'right". Is it the upper clock or the lower clock? That is what is the 'real' affect: speedup or slow down? IMO, it is basically nonsense to worry about which is real.
Oh, I am not asking which one reads out time as 'real' or whatever. I am just asking if there is a difference in the mechanism's action?
I think I sort of understand what you are saying and correct me if I am wrong.
The mechanisms (radioactivity) both work equally but from a different observer wrt to the gravitational source the time is dilated?
Say simply: the clocks are ran at two different positions, stopped, taken back to equal distance, and then compared to see how much time has passed? How is it that the rates were behaving equally if one sped or slowed? Or is that not what the experiment suggests? I think I may be confusing what the comparison actually is.
  • #37
Apophenia said:
Is GTD independent of an observer? For instance, when we measure clocks to run slower. They run slower merely as function of position to gravitational source? If not, I don't understand how a clock on Earth raised 12 inches requires an observer. Please explain. The observer is a clock not raised 12 inches?
The only way of measuring the passage of time is to observe some physical process: The swinging back and forth of a pendulum, the progressive graying of my hair, the Earth rotating about its axis and orbiting the sun, the oscillations of the the quartz crystal in my wristwatch, the back and forth bouncing of the light flash in the idealized clock I describe (not my idea... It's Einstein's) in this post, the decay of a sample of radioactive material, sand falling through an hourglass, ... All of these are clocks, meaning that we can measure the passage of time by observing them. This is what Einstein meant when he said the "time is what a clock measures".
But if the only way of measuring the passage the of time is to observe some physical process, then the only way of observing time dilation in action is to compare two physical processes. Therefore there will always be two clocks involved in any time dilation scenario, whether gravitational or speed-based, and the statement that time is dilating will always come down to a statement about how one clock/process is proceeding more slowly than the other.
  • #38
Ok, perfect sense. Thank you. This clears up my perceived ambiguity of GTD.
Is it not reasonable to say: gravity affects these mechanisms then?
  • #39
They aren't equal when you compare them. But neither can do any observation to suggest they ran slower/faster than they 'should have'. Only in relation to the other is there a difference.
  • #40
Is not a relation to the other suggesting just that? I am not sure what you mean by 'should have'.
Radioactive sample decaying to x amount of starting amount is defined as σ amount of time.
Same amount of starting radioactive sample can only produce a different amount of time (in relation to σ) by decaying to a different amount. Exactly a statement that time is dependent on the mechanism of the clock as Nuggatory was suggesting (if i don't take his post out of context).
Thanks
  • #41
Thanks
I don't understand what you are questioning. You can say that all processes (therefore time) ran differently for them between when they synched (then separated, then compared or got back together). You can't say which was fast or slow, except in comparison to the other. Is there something you think is true beyond this?
  • #42
I just want to make the distinction of what is implied by time. Yes, I know you need some reference to compare to but I see that is arbitrary to what I am saying. It seems that if you are going to say time then you are equivalently saying all processes...
which I think is pretty darn amazing and I think is heavily masked and even completely ignored by most people when they say time; also seems that a good deal who know about relativity completely so NO to that; they want to just say time while completely ignoring the mechanical aspect of what is measuring it.
Furthermore, it must be that all processes confirm this or saying 'time' in this sense is not correct (because it would not include all processes; i.e., there would be a clock with a mechanism that reacts subtly different to gravity for example). <- This is purely hypothetical to suggest further the definition of time as a result of all processes.
Another simple example: if cell processes don't slow accordingly with GTD then saying someone is aging (time is slowing) slower closer to a gravitational source is not correct and saying 'time' is slowing is not correct because it is process specific; I do not think this but again merely hypothetical.
I hope that clears up what I am trying to get across, although I am still unsure on how to rationalize Lorentz contraction and observer relative effects.People who are supposedly familiar with Relativity I have heard so far say: what is written above is not true and now between you and Nuggatory seems to apply it is if I take your meanings correctly (im attributing what you imply by how I understand what you two are writing...I don't wish to twist words). I would not be arguing anymore about GTD if this was resolved. There should not be discrepancy.
  • #43
I think different people are bugged by different things in learning relativity. To many, this is obvious - elapsed time is measured in the by physical processes; if time is different between two observers, it obviously means all their local physical processes were different compared to the other (esp. the scenario of separating and getting back together). The relativist obviously thinks biological processes, pendulums, radioactive decay, atomic oscillations, etc. all go in tandem, and that's what it means to talk about differential elapsed time without having to specify the particular process. Note that for each observer, all rates are normal, all laws are locally the same; you can't put your finger on anything except the difference along two world lines.
  • #44
I don't believe I have any disagreement with Nugatory. It might be instructive for you to try to express what you think that disagreement is.
  • #45
No, I don't either! You two seem to be in agreement.
You say "to many this is obvious...". Are you saying that is what is obviously true or that is what seems obvious but contradicts what is generally thought in relativity?
For a point you seem to agree with me then you say the "rates are equal...".
The physical processes must change relative to each other in different position from the source of gravity so Radioactivity or whatever mechanism changes, how can rates be equal?
*If you are going to measure time with radioactive decay how can you get to equally massed samples to decay to the same amount and say they are running at different times? (if that's what the particular clock depends on as a measurement)
If that's (*) not what you are inferring then I think we are in agreement.
  • #46
Why do you think we use the ideal light clock (two mirrors facing each other and fixed relative to each other) in examples and explanations? The thing is so simple that we don't have to worry about its mechanical aspects, can analyze the physics without constantly fretting over whether some mechanical idiosyncracy is going to distort our measurements.
In actual physical experiments, such as the classic Hafele-Keating, much of the experimental ingenuity and hard intellectual effort goes into devising clocks and other measuring apparatus that approximate the ideal as closely as possible, and in clearly understanding all of the physical effects that cannot be eliminated and might distort the results. Unfortunately, all of this hard work seldom makes it into the popular press; you read about an experiment and it sounds as if they just set it up one morning, did some measurements in the afternoon, and announced some earth-shattering results that evening. Not so.
  • #47
"All rates are equal..." - the physical processes must change relative to each other in different position from the source of gravity so Radioactivity or whatever mechanism changes?
Correct: relative to each other, they are different. Changing gets tricky. Changing from what? It is perfectly reasonable to say a clock raised in a gravitational field goes fast compared to one lower; and a clock lowered in a gravitational field goes slow compered to one higher. But I don't see how you can say either one changed - except in relation to the other.
  • #48
True, and consistent with what is generally taught in relativity. I think the perception of different is yours, and I'm trying to get you to express it clearly, because no one can help you if we don't understand this difference you perceive but we think isn't there.
  • #49
Just to be clear: if you take two identically prepared radioactive samples, raise one in a gravitational field; let them decay a bit; then bring them together, the amount of decay products will different. However, someone next to each sample would find it normal; the lower observer would claim the upper sample is decaying fast; the upper observer would claim, no, the lower sample is decaying slow. Despite the clear difference at the end, I don't see any meaningful way to talk about one or both of them changing (except as measured by the other). At the end, they both agree on the difference; but you can't pick one that 'really change'; nor can you say both changed - changed in relation to what?
  • #50
Apophenia said:
What I am saying is intuitively clear to myself.
Intuition has little place in modern physics. Our intuition simply wasn't designed to handle the regimes that modern physics deals with. We must hold to two higher standards than intuition: logic and evidence.
You insist that the concepts are intuitively clear to you. I suspect that is not the case. When things are actually clear then they can be defined clearly. I suspect that you feel intuitive clarity simply because no one has ever challenged you on these topics. Having not had to define and explain them you simply have not noticed the problems.
The term "observer" in relativity is usually shorthand for "a coordinate system where a given person or measuring device is at rest".
  • #51
Makes sense. Again I don't know what you mean by an observer watching the process (next to the sample as it decays) but when you bring the samples together one will be decayed less and one more. The one that decayed more (farther away from the gravitational source) can undoubtedly be said to decay at a faster rate (if we establish that less material left means faster decay rate), no? (that is after the samples are brought together. I don't know what an observer watching one of the samples implies; like actually perception and neurology slow and I don't want to bring that into it)
  • #52
One can be said to have decayed faster than the other; one can be said to have decayed slower than the other. The key thing is 'than the other'. You can't just say one decayed fast, without some specific reference. Other than that, maybe you've got it.
  • #53
Intuition in modern physics is a no. I understand where that comes from especially with quantum physics which Ill admit I am even more ignorant of. But take the example of posulated virtual particles "popping in and out of existence" as Krauss puts it. We intuitive know something can not come from nothing. I think the problem becomes intuitive when we observe what is really happening on a deeper level. Something from nothing is clearly not intuitive but virtual particles from interaction of something on a more fundamental level is. (something mechanistic would be my definition of intuitive). <- I am not going to say it has to be because I clearly dont/cant know.
Im not so sure about virtual particles and such. Some Krauss youtube videos are interesting but that's about the extent of what I know; I don't pretend to know much on it.
I challenge myself on the topic all the time and welcome constructive debate. I am actually glad moderators have not closed this one yet. :smile:
I seem to be getting somewhere.
Observer = coordinate system at rest (relative to what is being observed I am assuming)...
Thanks
  • #54
Well faster/ slower is how you define it I know. (i just go with the general thought that more material being decayed is 'faster').
But you are in fact saying there are differing amounts of radioactive material left in each clock?
I can make the somewhat superfluous example of:
take clock 1 in the middle of two clocks 2 and 3. 3 being closer to the source and 2 being farther. Define 1 as the arbitrary absolute sense of time (i.e., half the material decaying = 1 second). Now run all 3 clocks for that arbitrarily defined 1 second; until clock 1's material decays to half its original mass.
3 will have more radioactive material (time slows), 2 less (time speeds) in comparison to 1 which decayed to half of its original sample.
That is how I am seeing it. Is that flawed?
  • #55
Yes, definitely. The radioactive block that was at higher altitude before they are brought together will have more decay products.
That is fine except who gets to pick the absolute sense of time?
  • #56
It does not matter; the definition of a second is what's arbitrary.
Now you need to convince yourself (which you seem to have done) and DaleSpam that 1) and 2) (minus the ether stuff) are equivalent.
"detection" - The change of these mechanisms is precisely the detection of "mysterious, unknown" whatever we call gravity.
2) being essentially what I described to you and you saying "that is fine" with the addition of clear motive against it in the language (which I welcome to some extent as I have clear motive in mine to some).
I don't see a difference between the two (here in my words which are not the best):
1) Time slows down as predicted by relativity.
2) The mechanism which measures time slows down time as predicted by relativity.
Acknowledging that it takes a comparison of 2 clocks.
DaleSpam said:
The Michelson Morely experiment.
Time dilation has been measured using gravity, the strong, weak, and electromagnetic forces. There are currently no other known forces to account for.
Apophenia: If the mechanism behind the clocks all slow accordingly, then there is NO experimental difference between saying time slows or saying the mechanism slows as you would suggest.
Exactly. There is no difference. You are free to adopt either of the following two propositions:
2) Some mysterious unknown mechanism which cannot otherwise be measured or detected (e.g. the luminiferous aether) causes EM processes to slow down and coincidentally it just happens to slow down by the exact same amount predicted by relativity, AND a second mysterious unknown mechanism which cannot otherwise be measured or detected causes strong-force processes to slow down and doubly-coincidentally it just happens to slow down by the exact same amount as the EM processes and relativity, AND a third mysterious unknown mechanism which cannot otherwise be measured or detected causes weak-force processes to slow down and triply-coincidentally it just happens to slow down by the exact same amount as the previous two processes and relativity, AND a fourth mysterious unknown mechanism which cannot otherwise be measured or detected causes gravitational processes to slow down and quadruply-coincidentally it just happens to slow down by the exact same amount as the previous three processes and relativity.
I want to clear what seems like a discrepancy to further my own understanding of this all. 1) and 2) seem equivalent! Thanks to you both( and others...Nuggatory, and so on). Cheers
  • #57
At this point, arguing over 'all processes, whatever their nature, proceed according to relativistic predictions' versus 'time comparisons proceed per relativistic predictions' is silly. The two statements have the same content. It is like W.V.O. Quine's point that you can't distinguish 'undetached rabbit parts' from 'a rabbit'.
  • #58
Please stop randomly throwing in irrelevant topics. You posted about time dilation. Stick with that.
If you have questions about virtual particles please post them in the QM forum, and if you have questions about string theory please post them in the beyond standard model forum. When you post them here it seems that you are just trying to deflect the discussion.
  • #59
What is the discrepancy?
  • #60
Maybe If we cleared up something about gravitational time dilation it will help.
It seems to me that so far you have been thinking of it as being the relative strength of the gravitational field at different heights that results in the clocks running at different rates. It isn't. It is the difference in gravitational potential.
So why does this make a difference? Let's consider the following scenario:
Imagine we have a uniform gravity field. By uniform, I mean one in the the strength of the field doe not change with height. An object at one height experiences exactly the same gravity force as an object at a different height.
Now let's say that we have two identical pendulum clocks. We put them side by side and they tick in perfect sync. Now we put one of these clocks at a different height from the other. The clock that is higher will tick faster.
The only thing that physically effects the operation of the mechanism is the force of gravity, but both clocks experience the same force of gravity. Yet, the clocks will tick at different rates from each other.
  • #61
Deflecting is not my intent. I should just shut it sometimes. As for the discrepency: It seemed that some had the impression that you can say 1) and not mean 2) when now it seems 1) = 2) ... (until I read the next post). But other than that seeming to be an argument of semantics it is really saying that when you say 'time' you are inherently referring to all processes (anything that can be used to measure time) which I agree with you is seemingly too coincidental but how things 'seem' has no effect on what we observe. I think the next response clears this problem and put's me back into confusion though.
You are basically saying that there is NO physical effect on the mechanism which changes it's operation (other than gravity which is same for both so it does not matter within the context of what is being discussed). Get's back to my confusion of how the operation of a mechanism could change without something "physically effecting" (as you put it) it. You can simply say time changes (there is no physical effect) but I don't know what that means, anyone can't know what that means, but we may just have to take it and look at the whole thing mathematically. idk.
  • #62
1) and 2) are experimentally indistinguishable. Since they are experimentally indistinguishable there is no scientific way of choosing between the two. They are philosophically distinct, but many people regard experimentally indistinguishable positions as being the same in some sense.
Personally, I recognize them as being distinct, but feel that the distinction is unimportant.
  • #63
...and certainly unimportant for GPS design. By the way, is there a straightforward method for calculating GTD? Also, a geosynchronous satellite would be considered a coincident frame with the Earth so are there exclusively GTD effects acting upon them?
I understand your sentiments.
  • #64
If you know the gravitational potential, yes.
Something rotating together with Earth is not an inertial frame. No. You have to consider the velocity as well.
  • #65
Where curvature is unimportant you can use this approach: http://hyperphysics.phy-astr.gsu.edu/%E2%80%8Chbase/relativ/gratim.html
If curvature is important and you are dealing with time outside a non-rotating spherically symmetric mass then you need to use:
http://en.wikipedia.org/wiki/Gravitational_time_dilation#Outside_a_non-rotating_sphere
In more complicated situations it is not generally possible to split the time dilation into a "gravitational" and "motion" part. In such cases, the overall time dilation can usually still be defined. There are two typical processes for doing that. One is to simply calculate the frequency shift of signals sent, and the other is to calculate the ratio of proper time to coordinate time. The first doesn't work when signals cannot be exchanged and the second doesn't work if your coordinate system doesn't have a timelike coordinate.
  • #66
How would you combine the two TD effects. Is it just multiplication? The clean way to deal with the rotating common rest frame of Earth and geosynchronous satellite is to use the Schwarzshild metric for the rotating frame:
http://en.wikipedia.org/wiki/Geodetic_effect#Formulae
However, when I simply multiply the TD-factor from the non-rotating metric with the movement TD in the inertial frame, I get something else than the TD-factor from the rotating metric.
Also, what does dt in the rotating frame metric represent physically? In the non-rotating frame dt is the time of a clock at rest at infinity. But in the rotating frame we can't have an clock at rest at infinity. Is this still the time of an inertial clock.
