Zenner Diode Clipper: AC Voltage Spikes to 22V?
  • Thread starter Thread starter Daniel Floyd
    Diode
Using back-to-back Zener diodes can effectively clip AC voltage spikes from a Piezo Electric source to 22V, with options for either two 20V or 22V Zeners. It's suggested to avoid series resistance due to the high impedance of the source, which may hinder circuit performance. A diode rated for 400mW is adequate given the low current from the Piezo. For negative voltage spikes, a similar negative Zener diode setup is recommended. Proper connection and suitable ratings for the diodes are crucial for reliable operation.
Daniel Floyd
HI.
I am using Piezo Electric as a AC voltage source which gives voltage spikes of around 35V little current because the impedance of the material is verry high, I would like to clip this voltage to 22 Volts i have seen that a 2 x 22V zenner diodes can be used back to back is thie right or will i need a different value zenner for the negative?
also can anybody tell me what rating of diodes i will need?
Daniel Floyd said:
HI.
Yes, back-to-back or nose-to-nose Zener diodes make an effective bidirectional clamp. Since the source impedance of your source (the piezo) is high, you probably do not need any series resistance.
If you want the clamp voltage to be 22V, you can use either two 20V zeners or two 22V zeners. The forward diode voltage drop adds to the total clamp voltage, obviously. :smile:
EDIT -- OH, whoops. You edited your post since the last time I read it. Now instead of resistance, you are asking for what rating of diode to use. Since your currents are small, I would think that a small 400mW rated diode would work.
Thank you I have ordered some 22v zenner diodes in which I will use tomorrow.
I tried to use this before but this didn't work I assume its because I used a series resistance thus making my over all impedance very high which pretty much stopped my circuit from working. I will simple try using this back to back with no series resistance and see what result I get. Thank you
Check your zeners when you get them - some zeners use an internal second junction in series for better temperature performance . If you find that yours won't conduct when forward biased to their reverse breakdown voltage, you can use them in parallel rather than in series.
old jim
I would suggest using a 22V zener diode in parallel with a resistor to create a voltage divider circuit. This will effectively clip the voltage spikes to 22V without the need for two diodes. The resistor value can be calculated using Ohm's law, taking into account the maximum current that the circuit can handle. As for the rating of the diode, it should be able to handle the maximum voltage and current of the circuit. It is always best to choose a diode with a higher rating than what is needed to ensure reliability and safety. Additionally, for the negative voltage spikes, a similar circuit can be created using a negative voltage zener diode. It is important to ensure that the diodes are properly connected in the circuit and that their ratings are suitable for the application.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
