Electromagnetism, current in coil
A coil with 25 turns experiences a tension reduction of 4.0 x 10^-2 N when current flows through it, prompting a discussion on calculating the current's magnitude and direction. The relevant equations include F=IlB and B=μNI/l, leading to an initial calculation of 35.48 A, which does not match provided options. Participants express confusion about the direction of the magnetic field and its relationship to tension changes in the thread. The conversation also touches on the potential involvement of uniform circular motion in the problem. Clarification on these concepts is sought to resolve the discrepancies in understanding.
physics604
1. A coil of 25 turns of wire is suspended by a thread. When a current flows through the coil, the tension in the thread is reduced by 4.0 x 10-2 N. What are the magnitude and direction of the current? {magnitude of current; direction of current}
a) 4.1 A; clockwise
b) 0.16 A; clockwise
c) 0.16 A; counter-clockwise
d) 4.1 A; counter-clockwise
F=IlB
B= \frac{\mu NI}{l}
B=\muNI/l
F= IlB = Il(\muNI/l) = I2\muN
I = \sqrt{ \frac{F}{\mu N} }
so I = √4.0x10-2 / 4∏x10-7 x25 = 35.48A
My answer doesn't match with any of theirs.
Also, how would I find the direction of current? I don't know the direction of B (magnetic field).
Any help would be greatly appreciated.
Show your reasoning - why would you expect that a current through the wire would decrease the tension in the thread?
Just posting to get on the thread. Seems like there's a lot of info missing. Seems like this problem gives a whole new meaning to "pulling yourself up by the bootstraps"! :smile:
Is there uniform circular motion involved?
You are the one with the whole problem statement in front of you, you tell me: is their uniform circular motion involved?
