Python How Can I Vectorize a Computation in a Python Device Simulation Algorithm?
  • Thread starter Thread starter maverick280857
    Python
The discussion focuses on optimizing a computation in a Python device simulation algorithm involving the formula \(\tilde{G} = G \Sigma_{c}^{in} G^{\dagger}\), where both G and \(\Sigma_{c}^{in}\) are N x N matrices, with N around 5040. The initial naive implementation takes about two hours and sometimes crashes, prompting a search for vectorization methods to improve efficiency. A proposed solution involves recognizing that \(\Sigma_{c}^{in}\) is diagonal, allowing for a more efficient computation using nested loops, though this approach is deemed outdated. Participants also discuss the significance of \(\Sigma_{c}^{in}\) as a sum of inscattering matrices from a many-body problem, with no specific algebraic constraints on G. The conversation emphasizes the need for a more elegant and efficient computational method.
maverick280857
Hi,
I am working on a device simulation algorithm, and am implementing it in Python on my laptop that runs Arch Linux. A particular step requires me to perform a computation of the form
where G and \Sigma_{c}^{in} are both N \times N matrices, and \Sigma_{c}^{in} is in fact a diagonal matrix.
N is of the order of 5040
Now, if I do this naively, the command to do it in Python is
Code:
Gtilde_n = Gtilde_n + dot( dot(G, sigcIn), conjugate(transpose(G)) )
(The addition is for purposes of sub-band summation, and isn't relevant to the question I'm posing.)
but this takes about 2 hours when it works (sometimes it just crashes my laptop).
Now if I utilize the fact that \Sigma_{c}^{in} is diagonal, then I can do something more naive and write a for loop of the form
Code:
              for row in range(0,N):
                      for col in range(0,N):
                              sum = 0
                              for alpha in range(0,N):
                                      sum = sum + G[row,alpha]*sigcIn[alpha,alpha]*conjugate(G[col,alpha])
                              Gtilde_n[row,col] = Gtilde_n[row,col] + sum
But this doesn't look like a nice piece of code: it has 3 nested for loops, and looks a rather ancient way of doing the following calculation
\tilde{G}_{ij} = \sum_{\alpha}\sum_{\beta} G_{i\alpha}(\Sigma_{c}^{in})_{\alpha\beta}(G^{\dagger})_{\beta j} = \sum_{\alpha,\beta} G_{i\alpha}(\Sigma_{c}^{in})_{\alpha\alpha}\delta_{\alpha\beta} (G^{\dagger})_{\beta j} =\sum_{\alpha} G_{i\alpha}(\Sigma_{c}^{in})_{\alpha\alpha}G^{*}_{j\alpha}
Is there some way to vectorize this?
In general, is there a better way to perform this computation?
Technology news on Phys.org
maverick280857 said:
G_{ij} = \cdots = \sum_{\alpha} G_{i\alpha}(\Sigma_{c}^{in})_{\alpha\alpha}G^{*}_{j\alpha}
Trivially by partioning α's range for each ij, but I would rather try to exploit this
G_{i\alpha} G^{*}_{j\alpha} = \left(G_{j\alpha} G^{*}_{i\alpha}\right)^{*} or/and(given Σ is real, what I suspect) premultiplying all (G_{i})_{\alpha} vectors component-wise by a vector made of the Σ diag components. That could well be done in parallel.
Are there any known algebraic constraints on G?
Thanks for your reply.
No, its just the matrix representation of a Green's function.
What does this notation mean - \Sigma_{c}^{in}?
You said that it was a diagonal matrix, but I'm curious about the significance of c and in.
You're sure there's no constraint related to its eigenspaces?
So \Sigma_{c}^{in} = \Sigma_{1}^{in} + \Sigma_{2}^{in} is simply the sum of two so called inscattering matrices, computed from the self-energy in a many body problem. There are two terms because there are two contacts. For each contact,
\Sigma_{k}^{in} = f(E)\Gamma_k
k = 1, 2, and
\Gamma_k = i[\Sigma_k - \Sigma_k^\dagger]
It turns out that \Gamma_i[/itex] is a real matrix, i.e. all its elements are real.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
