Plausibility of a Discrete Point Manifold
Mandelbroth
Consider a discrete set of ##k## points.
First, is it a manifold? I know that a manifold is a topological space that contains a neighborhood homeomorphic to Euclidean space for each point. Can we just consider each point's neighborhood to be a set containing only that point?
Second, would the structure be orientable for ##k>2##?
You can, but then where is the homeomorphism to an open subset of \mathbb{R}^n? All singleton sets in \mathbb{R}^n are closed.
Every countable discrete space is a topological 0-manifold; the converse holds as well. Here a discrete space is a set equipped with the discrete topology. This is a trivial exercise so try to show it yourself. Define a topological n-manifold as a second countable Hausdorff space that is locally Euclidean of dimension n (i.e. every point has a neighborhood that is homeomorphic to an open subset of ##\mathbb{R}^{n}##).
And to add to this: yes, the manifold will be orientable.
I'm not very confident with this material, so...here I go:
Lemma #1: If the space is a countable discrete space, then it is also a second countable space.
//Proof: If the space is countable and discrete, then there are a countable number of singletons. The singletons can, therefore, form a countable basis for the discrete space.##\halmos##​
Lemma #2: If the space is a countable discrete space, then it is a Hausdorff space.
//Proof: If the space is a discrete space, then the points are necessarily disjoint. ##\halmos##​
Lemma #3: Each point in a discrete space is homeomorphic to ##\mathbb{R}^0##.
//Proof: Homeomorphism is the identity map. ##\halmos##?​
Considering lemmas 1, 2, and 3, we have established that a countable discrete space is a second countable Hausdorff space of dimension 0 with each neighborhood homeomorphic to Euclidean space of dimension 0, and therefore a 0-manifold. ##\blackhalmos##
I'm not sure about the third lemma. It feels too...blunt.
@Micromass: How is it orientable? Could you, perhaps...nudge me in the right direction?
(Also...you've not responded to my personal message about operators. It's been 3 weeks. :frown:)
That all looks good! Cheers.
