How do i demonstrate thin film interference with microscope slides?
To demonstrate thin film interference with microscope slides, using a hair between two slides typically produces parallel fringes, but achieving this can depend on several factors. Clean, optically flat slides and proper viewing angles are crucial, as direct reflections can obscure the fringes. While a red laser pointer and incandescent light bulb can work, polarized light may enhance visibility. The type of hair used can also affect results, with wispy hairs potentially yielding better outcomes than coarse ones. Proper orientation and technique are essential for successfully observing the interference patterns.
handsomecat
Textbook questions all mention that you will get parallel fringes when you put a hair between two microscope slides.
However, i have tried doing so, but don't get the parallel fringes. I used a red laser pointer, and a incandescent light bulb.
Is there something that I have missed? Do i need to use polarized light?
Science news on Phys.org
I almost always see fringes when two slides or coverslips stick together, no special lighting needed. Try it without the hair?
Likes 1 person
You get the best results from optically flat and clean slides (dry, too). You also get them, to everyone's annoyance, when you use plane glass holders for 35mm colour slides in an old fashioned slide projector. The colour fringes are often referred to as Newton's rings but they are all sorts of shapes. The smaller the angle, the wider the fringes, of course because they recur each time the spacing increases by a half wavelength. Is your hair 'wispy' or 'coarse'?
You have to get your head in the right place to view the fringes or the direct specular reflection can mask them.
Likes 1 person
thanks so much. You are right that the orientation is importont. I saw the fringes!
