Young’s double slit experiment
The forum discussion centers on solving a problem related to Young's double slit experiment, specifically calculating the linear distance between the first order (m = 1) and second order (m = 2) dark fringes. The slits are separated by 1.0 mm, and the light wavelength is 550 nm, with the screen positioned 12 m away. The calculations yield a distance of 0.00660 m between the dark fringes. Participants emphasize the importance of clearly stating questions and providing reasoning in solutions.
  • Understanding of Young's double slit experiment
  • Familiarity with wave optics and interference patterns
  • Knowledge of trigonometric functions in physics
  • Ability to perform unit conversions (e.g., nm to m)
  • Study the derivation of the formula for dark fringes in Young's double slit experiment
  • Learn about the significance of fringe spacing in interference patterns
  • Explore the impact of slit separation and wavelength on fringe visibility
  • Investigate common mistakes in applying trigonometric functions in physics problems
Students studying physics, particularly those focusing on wave optics, as well as educators looking for insights on teaching problem-solving techniques in interference phenomena.
aChordate
In a version of Young’s double slit experiment, the slits are separated by a distance of
1.0 mm. The light from the slits is observed on a screen that is 12 m from the slits. If the
wavelength of the light is 550 nm, what is the linear distance on the screen between the
first order (m = 1) and second order (m = 2) dark fringes?
sinθ=(m+1/2)λ/d
sinθ=(1+1/2)550nm/1mm=8.25*10^-4
θ=0.04727°
sinθ=(2+1/2)550nm/1mm=0.001375
θ=0.07878°
tanθ=y/L
y = Ltanθ = 12tan0.04727
y=0.00990 m
y = Ltanθ = 12tan0.07878°
y=0.0165 m
0.165-0.00990=0.00660 m
Cool!
Was there a question in all that?
I see your attempted solution is incomplete - no reasoning provided, and no conclusion.
Why did you pick that particular equation?
What do you mean, "was there a question in all that?"
Exactly what I said - you wrote quite a lot, but you have not asked a question.
The most important part of science is asking questions - you should practise.
In the English language, a question is a sentence that ends in a question mark and frames some sort of query.
In your entire post, the only question mark appears in the problem statement - that is a question being asked of you, as homework, so I am not allowed to answer it.
You have done the physics problem, and shown your working.
That's fine - but so what?
Perhaps you wanted to know something?
aChordate,
Your solution is correct, I think, you just wanted us to check it. Simon misses the question "Is my solution correct?"
But a solution is really good if you explain what you do and why.
During the solution, do not use the same notation for different things. If y is the position of a dark spot, write y1 for the first one and y2 for the second one. At the end, give the result in a sentence: " the distance between the first and second dark fringes on the screen is d=y2-y1=..."
By the way, the first dark fringe that appears in the Young experiment corresponds to 1/2 λ/D, when m=0 (between the central maximum and the first maximum)
ehild
... which does not appear in post #1 at the time of writing this.
I could "infer" this question - but it could be that OP has a specific concern that should be addressed.
I could infer the question, "How can I improve on this?", which changes the style of the reply.
Like I said, getting an explicit question helps show how the OP is thinking about the problem.
Answers in related thread has apparently shown that OP does not understand why the equation chosen is correct.
Technically, the distance between any two adjacent dark fringes will be, given the geometry, the same - and that will be the same as the distance between two adjacent bright fringes too.
Note: 0.07878deg = 0.001375rad,
tan(0.001375rad)=0.001375 ...
sin(0.001375rad)=0.001375 ...
... should suggest an approximation that would help you in future.
11K
