Why Do Capacitors Accumulate Charge?
  • Thread starter Thread starter Avichal
    Capacitor Works
Capacitors accumulate charge on their plates due to the attraction between opposite charges, creating an electric field. When a voltage is applied, electrons flow until the voltage across the plates equals the applied voltage, resulting in a balanced energy state. The charging process continues until the energy per electron is the same on both sides, preventing further flow when the circuit is open. This behavior is similar to static electricity, where charged objects can influence each other. Ultimately, a capacitor stores electrical energy, analogous to a water tower storing water under pressure.
Avichal
After studying more complicated electronics, I find myself asking this question - 'Why capacitor works?'
Why does charge get accumulated on the plates? Isn't that a higher energy state than battery?
Opposite charges attract each other, and the other side has the opposite charge.
No, the capacitor gets charged until the energy per electron is the same in both.
Likes 1 person
Why is it not a higher energy state? When the circuit is closed I understand why electrons flow. But when it is open(which is in this case), I don't understand why electrons should flow.
The circuit is only "open" when the capacitor is fully charged. Until then current will flow into one plate and out of the other until the voltage drop across the plates is equal to the applied voltage.
If you are familiar with static electricity you will know that it's possible for an object like a plastic comb or rod to become charged up (eg it acquires a surplus or shortage of electrons). Much the same thing happens with each plate of a capacitor...
Imagine one plate (lets call it the top plate) behaves like a comb that you have charged up with extra electrons. If that top plate is close to another plate (eg the bottom plate) then the electrons in the top plate will repel electrons in the bottom plate (like charges repel remember). The electrons in the bottom plate will try to move away from the top plate by escaping down the wire.
So now you have electrons on the top plate and a shortage of electrons on the bottom plate... and for awhile you had current flowing. You put electrons into the top plate and different electrons left the bottom plate.
If you have electrons on one plate and a shortage on the other then there will be an electric field/ voltage between the two plates. This voltage will build up until it's greater than the voltage that caused the surplus of electrons on the top plate. At that point no more electrons flow onto the top plate or out of the bottom plate.
A capacitor is somewhat analogous to a water tower. You can pump water in, then close off the gate. Later, you can open the gate and water will flow out. Now replace water with charge, and water pressure with voltage.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
