Finding north with copper wire
To determine north using a copper wire and a voltmeter, create a large vertical loop with the wire connected to the voltmeter. As you spin around at a constant speed, the Earth's magnetic field will induce an electromotive force (emf) in the loop. The induced emf is highest when the rate of change of magnetic flux is greatest, which occurs at specific points during your turn. By observing the maximum deflection on the voltmeter, you can identify the direction of magnetic north. This method effectively utilizes electromagnetic principles to navigate when lost.
MmeCurie
How do you figure out which way is north when you're lost and the only things you've got with you is a copper wire and a voltmeter?
Thanks in advance.
Thanks in advance.
1. What happens when you wave a copper wire about in a magnetic field?
2. When is this effect most and when is it least?
Answer those two questions and you're on the way to a solution.
Thanks in advance.
Make a loop of the largest area that you can make with the copper wire and voltmeter leads (connected to the voltmeter) using your arms while orienting the loop vertically. Then, standing up, turn around as fast as you can but at constant rotational speed while watching the voltmeter.
Since the Earth's magnetic flux through the loop is changing as you turn, there will be an induced emf around the loop. The magnitude of that induced emf is proportional to the rate of change of that flux. At what point in your turn (letting 0 degrees be due magnetic north) will the time rate of change of magnetic flux be maximum (ie. where you will observe maximum deflection of the voltmeter)? Figure out north from that.
AM
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
