Is the Field Operator in Quantum Field Theory an Observable or a Creation Tool?
  • Thread starter Thread starter Kontilera
    Intuition Qft
Kontilera
Hello!
I'm finally starting to get a grip around quantum field theory. The last hang up is the following:
I've been told that since we are quantizing a field, the field strength is the observable. Now analogous to QM we then define a field of hermitian operators, ##\phi(x)##, which give a hermitian operator in every point in spacetime (i.e. for every observable). However in most books the field ##\phi(x)## is introduces as a excitation/creation field. These two interpretations seems to be contradicitve.
If say ##\phi## is nonzero only at a point x (lets forget about smoothness conditions), and we act on a state with it.. it seems to me that we should expect the following result according to the first definition:
\phi \mid \psi \rangle = \psi(x) \mid \psi \rangle
and the following according to the second:
\phi \mid \psi \rangle = \kappa \mid \phi, \psi \rangle.
Is the first interpretation wrong or can they be fused togheter in some way?
You just choose different bases. With the annihilation and creation operators wrt. the single-particle momentum eigenstates you create the Fock basis (occupation-number basis), i.e., states with determined particle number. The other basis is overcomplete and the eigenstates of the fields. The latter you use to establish the path-integral. For further explanations, see my QFT manuscript:
http://fias.uni-frankfurt.de/~hees/publ/lect.pdf
Kontilera said:
Hello!
It's just like the harmonic oscillator in regular QM. There the main observable is ##x##, but we can write ##x## as a sum of creation and annihilation operators: schematically ##x = a + a^\dagger##, ignoring normalizations.
In the QM of the harmonic oscillator, there are two useful bases for the Hilbert space. There's the position basis, in which ##x## is diagonal. Then there's the Fock basis, in which the Hamiltonian is diagonal and ##a## and ##a^\dagger## are seen to be lowering and raising operators.
Similarly in QFT you can consider two bases. In one the field operator ##\phi(x)## is diagonal. This basis is not too useful, though. The more useful basis is the Fock basis, consisting of states of definite numbers of particles each with definite momentum.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
