How Is the Integrating Factor Used to Solve Initial Value Differential Problems?
vanitymdl
Problem: Find the solution to the initial Value problem (differential equations)?
y'=-y+e^-2x
y(0) = 3
Attempt: y' -y = e^(-2x) ----- (1)
Linear equation of first order of form y' + y p(x) = q(x)
p(x)= -1
q(x) = e^(-2x)
Find the integrating factor e^∫p(x) dx = e^∫ - dx = e^-x
Multiply equation (1) by the integrating factor e^-x
y' e^-x - y e^-x = e^(-3x) ----- (2)
The left-hand side of (2) is the derivative of y times the integrating factor or (y e^-x)'
(y e^-x)' = e^(-3x) ----- (3)
Integrate both sides of (3)
y e^-x = ∫ e^(-3x)
y e^-x = (-1/3) e^(-3x) + C
multiply everything by e^x
y = (-1/3) e^(-2x) + C
y(0)=3
3 = (-1/3) e^0 + C
C = 3+1/3 = 10/3
y = (-1/3) e^(-2x) + (10/3) e^xHow does this look?
y'=-y+e^-2x
y(0) = 3
p(x)= -1
q(x) = e^(-2x)
y e^-x = ∫ e^(-3x)
y(0)=3
3 = (-1/3) e^0 + C
C = 3+1/3 = 10/3
How does this look?
The first thing you should do is to substitute your solution back into the d.e. Does it solve the equation?
Is this ##y' = -y + e^{-2x}## or is this ##y' - y = e^{-2x}## your equation?
Because in the problem statement, you gave the former, but you solved the latter. The solution for the latter is correct, but if you made a simple algebraic error in bringing the ##y## over, then the solution is obviously wrong.
y'=-y+e^-2x
y(0) = 3
p(x)= -1
q(x) = e^(-2x)
y e^-x = ∫ e^(-3x)
Isn't C included in the "everything"?
Yes, it should be. The reason it didn't affect the answer is because ##e^0 = 1##.
Why not using the standard way of solving linear equations, i.e., first solving the homogeneous equation
y'=-y
and then using the ansatz of the variation of the constant?
y'=-y
The integrating factor is the usual elementary method that's taught for questions like this, I think.
I was about to suggest using a Laplace transform, which gives a quick algebraic solution in an initial value problem like this, but thought better of it, simply because it's unlikely the thread starter has covered it yet.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
