How does the varying resistor affect the voltage at node 2?
The discussion focuses on how a varying resistor impacts the voltage at node 2 in an op-amp circuit. The 4.7k ohm resistor connects to node 3, and the varying 100 ohm resistor acts as a potentiometer, affecting the voltage at node 2 based on its position. When fully turned towards node 3, node 2 receives 5V; when turned towards node 1, it receives 0V, and halfway it receives 2.5V. The voltage at node 2 can be calculated using the potential divider formula. Understanding these relationships is crucial for solving the circuit effectively.
mathrocks
I have to solve an op amp circuit for a lab I'm doing but the circuit they have given me looks confusing (it's on page 46, http://filebox.vt.edu/users/oshekari/Manual_Student.pdf). Why does the 4.7k ohm resistor have an arrow pointing to the middle of the 100 ohm resistor? I know the 100ohm is a varying resistor but if I were to actual solve the circuit for output and leave the varying resistor at 100ohms would the 4.7k be connected to node 3 or to node 1? And if it is indeed connected to node 3 then how would I go about doing nodal analysis at that node since I don't know the current to the left of the node, I just have a voltage source.
Correct if I'm wrong but at node 3 the nodal equation is: 5/x+(v3-v1)/4.7k+v3/100. Where x is the resistance, v3 is the voltage at node 3, and v1 is the voltage at node 6.
Now are we assuming this op-amp is ideal? For laboratory purposes I would suspect that it is not--- however I did not read your lab to find out the Rin, A and Rout values.
Yes, it's an ideal op-amp.
Hi,
I forgot my nodal analysis learned during 1st year, but I can give you some light on the 100 ohms varying resistor.
Whether the varying resistor is 100 ohms or 1kohms is of no concern in the amplifier circuit because it effectively acts as a potentiometer OR potential divider. Whatever the voltage at node 2 depends on the position of the dial: If it is at node 3, the voltage at node 2 is the full 5V : If it is at node 1, the voltage at node 2 is the full 0V : If it is halfway in between, it is 1/2 * 5V = 2.5 V.
This is because as you turn the dial downwards, the resistance with respect to node 1 decreases, and the resistance with respect to node 3 increases.
The voltage at node 2 can be found using the potential divider formula:
R1/(R1+R2) * Vcc.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
