Standard Electrodes: Pressure & Half Cell Potential Impact
Maintaining a pressure of 1 atmosphere in standard electrodes, particularly in standard hydrogen electrodes, is crucial because the potential of a half-cell is indeed influenced by pressure. The relationship between gas pressure and concentration is governed by Henry's law, which states that the concentration of a dissolved gas is proportional to its partial pressure above the solution. This means that as pressure increases, the concentration of dissolved hydrogen also increases, affecting the electrode potential. Using pressure as a standard state simplifies calculations and aligns with the convention of defining standard conditions, just as a 1M concentration is used for ions. Therefore, standardizing at 1 atm ensures consistency in measurements and comparisons of electrode potentials across different systems.
ajayguhan
In standard electrodes, why it is necessary to maintain the pressure as 1 atmosphere, is the potential of an half cell depends on pressure too? If yes then how the potential of an half cell depends upon pressure?
Say for example, i know that in standard hydrogen electrodes we maintain the concentration and temperature as 1M and temperature 25°C since the potential depends upon temperature and concentration of the electrolyte.but why should we maintain the pressure as and1 atmosphere? If the potential depends upon pressure, how come they are related i didn't get the logic!
Chemistry news on Phys.org
Note that the concentration of the dissolved gaseous hydrogen is directly proportional to the pressure of the gas over the solution (even heard about Henry's law?). But dealing with the concentration is inconvenient, it is easier to express the gas presence using its pressure. And just like we assume 1M solution is the standard state for an ion, we assume 1 atm is a standard state for the gas.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
