Finding natural frequency of a steel flat
To find the fundamental frequency of a steel flat with dimensions L=1000 mm, B=100 mm, and T=10 mm, fixed at both ends and with weights suspended at 250 mm and 750 mm, Dunkerley's method can be applied. This involves calculating the natural frequency due to the beam's weight and the deflection caused by each point load separately. The overall frequency can then be estimated using Dunkerley's formula, which may slightly underestimate the actual frequency. Additional resources provide detailed engineering approaches for more complex scenarios. This method offers a practical approximation for determining the natural frequency of the specified steel flat.
lonthia
is there a straight formula for finding one of the natural (preferably fundamental) frequency of a steel flat with dimension say, L=1000 mm, B=100 mm and Thickness T=10 mm ? The flat is fixed at both ends by bolts and two weights of equal magnitude are suspended at 1/4 and 3/4 (i.e. 250 mm and 750 mm) of the flat.
I am yet to find understandable solution to the above problem on the net; so I had to post it to this forum. Please help, I am lost.
This article gives an engineering approach to estimating the fundamental frequency of a shaft under various end conditions and loadings:
http://www.impactap.com/joe/Chapter%207.pdf
Dunkerley's method is outlined in this article:
http://www.freestudy.co.uk/dynamics/free vibrations.pdf
Basically, you can calculate the natural frequency of the beam under just its own weight, and under the deflection due to each point load, separately, and then find the overall frequency by using Dunkerley's formula. This formula tends to underestimate the actual value of the frequency. There are more complicated approaches to finding the natural frequency, but this should give a close approximation.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
